3500 Shift points
  • asylummotorsports
    Banned
    • Oct 2005
    • 649
    3500 Shift points
    Here's the set-up. '92 Beretta.
    3500, S&S headers, 65mm TCE TB, 3:73 FDR with an EP LSD.
    Motor is 100% uncracked stock.
    I have been shifting at 6000 RPM, but it really seems that it is still pulling hard.
    How good are these valve springs/cam specs?
    Thanx.
    do you have a dyno close?
    the springs are similar to the LS1 so they should be ok till about 6500 or so, a quick run on the dyno would show you where it's making the most power.
    • Barry
      95 Beretta LG8 Action
      • Aug 2007
      • 269
      If you can hold it in gear then you can do what Dave said. But with Bfest NE coming up fast, I doubt you will have time.
      6500 shouldn't be out of question though. Stock limiter in the g6 is 6k?
      95 Beretta- Lg8 Daily Driver
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        I would guess with that combo, 6400 is about peak power.
        • kflo 93 gt
          Bangin' Gears
          • Nov 2003
          • 238
          Dyno it! Dyno it! Dyno it!
          14.60 @ 96.33 for now...
            I would love to see dyno numbers on this too.
            • Chris88CL
              Moderator
              • 212
              Ditto! Toss it on the rollers old timer!
              • asylummotorsports
                Banned
                • Oct 2005
                • 649
                I'll get this engine to a dyno over the winter when it's in the new car.
                For now it seems quite happy in the 6000-6200 range. I'm not sure I really want to take it much farther than that, DO I?
                Thanx folks.
