Muffler installed
  • 1995 Gold Ciera
    Has too many questions...
    • May 2008
    • 114
    Muffler installed
    Hey guys, I just got the Hooker Aerochamber installed with 2.5" piping from the cat back. I went with a Magnaflow dual rolled tip. It looks nice, like it belongs there but not too flashy. Anyway, it ended up being A LOT louder than I thought it would be. That's not a bad thing though. I did notice some improvement while accelerating, it seems to wind out harder and not "lose steam as quickly." Any ideas as to what kind of gain I may have gotten?
    The only downside that it has is that there is a drone at certain points of throttle, but oh well, you can't have it all. Other than that it sounds pretty nice and I'm sure the 3400 UIM/LIM swap will benefit even better from this mod. Then comes the cam at tax season....
    Btw... pics will come soon. I don't have my camera with me at the moment.
    1995 "Driftwood Metallic" Cutlass Ciera
    Mods: K&N airfilter, Addco Front & Rear Swaybars, 2.5" cat-back exhaust w/ Hooker Aerochamber muffler.
    Down the road: Cam(?), 3400 ported UIM & LIM, ported heads.
    A new downpipe and cat would help too. If your downpipe is like other 3100's, it's 1.5" ID dual walled...
    • 1995 Gold Ciera
      • May 2008
      • 114
      It most likely is. I have to find a local performance shop that is willing to take the time to work on it. Too bad no one makes aftermarket ones or headers for the 60*.
      • mike0589
        I Love My 60*
        • Feb 2007
        • 30
        Agreed. Someone i know put a 2.5'' DP on a near stock L82 grand prix. And it seemed to help out almost as much as my intakes did.
        1998 Monte Carlo LS, Dark Carmine Red Metallic.
        P&P 3400 UIM, LIM, And TB.
        Custom FWI / Descreened MAF.
        Polyurethane Dogbone Engine Mounts.
        MMS PCM, Dyno Tuned.
        180*T-Stat.
        Custom Shift Kit.
        Taylor ThunderVolt 8.2mm Spark Plug Wires.
        LQ1/LHO Oil Filter.
        GMPP Front And Rear STB's.
        SS Rear Brake Lines.
          If you don't have a section of pipe after the muffler going to the tips, it will have more drone that if you did. when I had my tips rust off (used cheap pipe of course to them) then the muffler droned really bad with no pipe/tip on it.
          • 86euro
            • Dec 2006
            • 219
            You may want to think about changing the rear manifold to the center dump style, I think it has a larger outlet than the a-body offset outlet manifold.
            • YALEROYNOT
              • Aug 2008
              • 14
              I am parting out my alero I have a magnaflow high flow SS cat and 2.5 down pipe I could remove and sell ? pm me
              • 1995 Gold Ciera
                • May 2008
                • 114
                PM sent...
                Anywho, does anybody have any ideas on how to deaden the sound a bit on the inside in general. I like it loud but I have two little ones and I don't want to hurt their ears.
                  That downpipe won' fit your car, or the flange on it.
                  • 1995 Gold Ciera
                    • May 2008
                    • 114
                    Thanks for the heads up man. I'm not going to go that route right now anyway. I'm looking for the UIM & LIM (finally)
                    Anyway, a friend of mine told me that some sound deadening material under the trunk mat and behind the rear seat might help with the loudness. Is this true?
                      Possibly, if the trunk is acting like a drum and vibrating due to the sound.
                      How long is the pipe that goes to the tips?
                        Aerochambers are designed not to drone.. kinda strange.
                        Normally i have 2 layers of sound deadning carpet padding under my trunk carpet, plus with my back seat folded up mine isn't loud at all.. currently i have no interior.. just a drivers seat and yes, it is loud
                        Maybe some good automotive padding or some spray in sound deadener would help..
                        • 1995 Gold Ciera
                          • May 2008
                          • 114
                          I believe the tip is connected directly to the muffler.
                          I think this may be the problem. Yesterday I lifted up the trunk carpet and there is some very cheap deadening material on the passenger side but absolutely NONE on the drivers side whatsoever or on the back of the rear seats. It's just the sheet metal on the trunk floor and springs on the seat. The thing that really makes me think it's the trunk is that it seems to sound okay on the outside but gets louder on the inside.
                          Is there a type of deadening material that you guys would recommend? I was planning on just doing what you did Dave and laying down a layer or two. I'm not gonna bother gluing it in case I ever want to take it out.
                          • torq455
                            If I only had money!!!
                            • 1615
                            Dynamat. sound deadening and antivibration as well.
                            Andy
                            fastest 1/8: 10.19@ 67.17
                            fastest 1/4: 16.16@ 82.70
                              If there was some pipe length to the tips it would help drone I bet.
