boring out the 3100
  • 93grandprixse
    • Aug 2005
    • 35
    boring out the 3100
    is it safe to bore out a 3100 .120" just curiouse because this would bring me to .020" over a 3400 bore and i could use the weisico forged pistons...
    also, has anyone heard about copper ringing instead of head gaskets?
    • 9191
    Its been done before, but I'm not sure its 100% safe. If you did it, I would definately get the block sonic checked before I did anything else. You'd probably be better off finding a 3400 block and boring it .020" over. I know I wouldn't install forged pistons into a block that has been bored .120" over. No reason for the forged pistons as the block will probably fail before anything else
    • 93grandprixse
      • Aug 2005
      • 35
      iv heard from a guy that used to work at gm that you could safely bore my block to 3500 because its basicly the same thing... i assume he was false?
        • 9191
        The 3400 blocks have more meat to them than the 3100 blocks. And the 3500 is a slightly different beast. Not sure on wall thicknesses between the 3400 and 3500, but there are some other machining differences between the 2.
        • Azrael
          Accelerating uphill in OD
          • Apr 2005
          • 763
          I've heard of someone boring there's out to 3.3L.
          1995 Grand Am SE
          • montess408
            • May 2006
            • 391
            the difference between the 3100 and the 3400 is .120 and the difference between the 3400 and 3500 is .080
            so i think if sonic checked before boring the 3400 can be bored out to the 3500 bore but to bore a 3100 .125 is riskie !
            i heard air motor's boring out 3.1 .100 to make a 3.3 so maybe that could be done
              Don't risk it.. 3400's are easy enough to find.
