4.3 TB swap Q's
  • dragogt
    • Oct 2008
    • 4
    4.3 TB swap Q's
    Will the Edelbrock intake work for this, or do I need to find another 3.1 intake?
    Or is there a different after market intake that will compliment the 3.4 swap? And still be able to keep the TBI?
    92 Isuzu Rodeo 5sp 4x4
    87 F150 2wd aod
    83 bronco c6 waiting for a diesel
    86 mustang GT T-top 5.0 5sp
    83 mustang GT 50 5sp
    Aaron
    http://nwuonline.com
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Keep the stock intake and bore it out for the 4.3L TBI unit. The TBI intake is actually quite good. Just clean up the casting and gasket match it. Thats about as good as your going to get.
    • dragogt
      • Oct 2008
      • 4
      Allright-E-then.
      87 F150 2wd aod
      Aaron
      • 1meanz
        • Nov 2007
        • 197
        not tryin to thread jack, but will that make that big of a difference?
        • dragogt
          • Oct 2008
          • 4
          From what I understand the throttle blades on the 4.3 tb are a lot bigger than the 3.1 intake bores, so yeah by being able to open them all the way up should make a big difference. Kinda like going from a 2bbl carb to a 4bbl carb.
          87 F150 2wd aod
          Aaron
          • BoostED00GagT
            BooStIN!
            • 38
            ive got a 4.3 t.b.trying to think of ways to fab up to my 3400 intake mani..do i go with an adaptor plate and hog out the intake inlet more...do i make a custom upper plenum..any ideas?
            00 turbo'd gagt msd 8.5 mm wires,ngk tr-6 plugs,42.5lb inj,65mm tce t.b,ported upper intake,ported lower,ported heads,copper headgaskets,headstuds,160 stat,ls6 valve springs,st3 turbo cam and pushrods,turbo manifolds,custom 'y' pipe,3in open d.p.,dhp powr tuner,garret t3 60-1 .63 turbine,70 compressor,6 pounds of boost...STOCK CAM,STOCK 103XXX BOTTOM END...2.041 60',13.683 @ 100.34
            99 gtp 4in. F.W.I...180 stat..headers...104's...msd8.5's..1.9's...3.4 pulley...cat & res./
            • dragogt
              • Oct 2008
              • 4
              I don't know bubba, one of the other guy's on here can answer that better than I can. You can see from my sig where my loyalty's lie.
              87 F150 2wd aod
              Aaron
              • geoffinbc
                • 5831
                We're not talking about the same parts here. Your talking about a throttle body from a 4.3L Vortec. We are talking about a bigger throttle body from a 4.3L with Throttle Body Injection. Completely separate issues and in no way are the parts similar.
