installing a 4 wire heated o2
  • 923.4v6
    • Feb 2008
    • 182
    I started to install a 4 wire o2 in place of my one wire none heated o2 sensor. My question is it has 2 black wires which I believe are the grounds and a white and a blue, is the white the hot and the blue the one to the ecm?
    that should help.
    • torq455
      If I only had money!!!
      • 1615
      iirc the two black wires are grounded together on my car. either way, the pinout will be correct no matter of the colors.
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
      • 923.4v6
        • Feb 2008
        • 182
        thanks, we'll see how the the o2 readings show with the heated one.
        • 923.4v6
          • Feb 2008
          • 182
          ok I got it in and the thing says its ready and ok in tp aldl flags, but keeps saying I have 446.42 o2 volts untill I switch it off. Everything else in tp is seems to be working fine, is there anything that may be turned off to cause it to show it all the time?
