3400 + boost
  • montess408
    • May 2006
    • 391
    3400 + boost
    hey i have a 3400 with higher miles on it but it's got good oil pressure and good compression .
    and i would like to put boost to it if i can pice up a kit . what is the highest psi of boost i will be able to get with out f/ing the bottom end ? and how much power would it ruffly give me ?
    B.T.W. i will be S/C with a m62 or m90
  • BoostED00GagT
    BooStIN!
    • 38
    ive got a 3400 grand am with a turbo and cam with 104xx miles on the stock bottom end and ive hit 15 pounds of boost...dont do that all the time...but it held together...stil gotta get numbers tho..id say stick around 6-10 pounds of boost to be safe
    00 turbo'd gagt msd 8.5 mm wires,ngk tr-6 plugs,42.5lb inj,65mm tce t.b,ported upper intake,ported lower,ported heads,copper headgaskets,headstuds,160 stat,ls6 valve springs,st3 turbo cam and pushrods,turbo manifolds,custom 'y' pipe,3in open d.p.,dhp powr tuner,garret t3 60-1 .63 turbine,70 compressor,6 pounds of boost...STOCK CAM,STOCK 103XXX BOTTOM END...2.041 60',13.683 @ 100.34
    99 gtp 4in. F.W.I...180 stat..headers...104's...msd8.5's..1.9's...3.4 pulley...cat & res./
    • Nick-G
      11's or Bust...
      • Feb 2008
      • 224
      First of all you cant mount an m90 on the 3400. I'm assuming your talking about the 3800 m90 like most people and it will not fit.
      Second of all since it doesn't seem like you have one already where are you planning on getting an m62? As far as I know I am the only person around here who has an m62 for sale.
      BUILT Turbo 3400/4t65e-HD powered Grand AM in the making.
      • Mars
        • Apr 2004
        • 826
        Put better valve springs in it and the problem saver intake gaskets, and you'll be golden at 14 - 15 psi with a good tune all day long. I've been doing this for something like 4 years now.
        I am still thinking om making a M90 S/C 3400 in a RWD off -road vehicle, just by making a sheet metal (more like plate steel) upper intake manifold and just bolting the SC right to that.
        • montess408
          • May 2006
          • 391
          i got a m62 off of a 93 buick car but i am looking at a other one and it's a m90 it depends on how much he wants for it i may get that one. and as for mounting it it will not sit on top like it does on the 3800 i know that it will not fit that way but a little bit of custom work goes a long way
            gen5 blower would be nice from the sIII gp..
            • montess408
              • May 2006
              • 391
              yeah we could probly turn up the boost with one of them !
              but for now i will stick with the m62 just to see if i can make it work
                the gen5 is more efficient than the previous m90 blower. Is an m62 big enough for a 3400?
                • montess408
                  • May 2006
                  • 391
                  ??? i don't know much about boost but it came off a 3800 series 1 so i guess it can work it may be taped out but just to get a working prototype it's worth trying
                  • kwhauck
                    Olds Sleeper
                    • Aug 2006
                    • 379
                    yes and no, yes with supporting mods you can make 300fwhp with the m62, i made 281 on stock motor with fuel upgrades and w2a intercooler (gen4 m62 blower) but the hEatons max out on the 3400 at about 13-15psi, so it really depends on your power goals.......me personally....i ditched the hEaton for a whipple.....
                      Nice! Got any pics of your setup?
                      • kwhauck
                        Olds Sleeper
                        • Aug 2006
                        • 379
                        well, the whipple build is still ongoing, I can dig up some of the m62 pics if you want?
