3400 help
  • z-man350
    • May 2008
    • 12
    3400 help
    how much hp can you get out of 3400 with out touch my obd 1.5
  • Azrael
    Accelerating uphill in OD
    • Apr 2005
    • 763
    No one really knows for sure. But I recall someone from another forum who knew a guy who knew a guy who knew some engineer at GM and said that the OBD 1.5 system can relearn up to %20 more than what the ECM was originally programmed for...whatever that might mean. Take it with a pinch of salt.
    Considering most 3x00 V6 OBD1.5 cars came with either 17 or 19lbs/hour injectors, that would be enough fuel for about 220HP and 245HP respectively. Running higher fuel pressure can bump those figures up a bit but don't expect much.
    1995 Grand Am SE
    • z-man350
      • May 2008
      • 12
      how can i raise my Compression ratio on my 3400. how much will a 3.4 camaro head gasket bring Compression ratio up too. i would like to bring it to 10.5:1
      • z-man350
        • May 2008
        • 12
        some body
          • 9190
          http://60degreev6.com/content/CR_Calculator
            you shouldn't run 3.4 camaro gaskets on a 3400, your piston to head clearance would become an issue.
            about the only way to cheaply raise compresison on a 3400 is with a piston swap to the ones from a 3.4 Camaro.. which would net around 12.5 or 13:1.
            OBD1, 1.5 and 2 will all compensate to a certain degree, but adding in a large cam will throw things all out of wack. it's just best to swap to OBD1 or 2 to gain the ability to tune.
            • 19Cutlass94
              • Apr 2005
              • 770
              Im running a 1211 grind cam and p&p'ed intakes on my 94 Olds with OBD1.5. Ive got a slight issue I need to figure out, but before this issue happened its been running strong, and with all the data scans Ive done, and AFR's it seems to be pretty good ( well as good as it will be without tuning )
              3400/Getrag 284 5spd
              350/NV3500 5spd
              2014 Chevrolet Malibu LS
