Cruise Control?
  • Bryan921SS
    • Nov 2008
    • 4
    Cruise Control?
    Hey everyone, I own a 96 Cutlass Supreme 2 door and my cruise control has been dead for a while now....I would like to know what I should be looking for.
    The module is in good condition, the electrical plugs are hooked up correctly, and the cable is nice and taught. I think the problem lies with the switch, but before I start taking my column apart I wanted to know if anyone around here has done the same, or had CC problems.
    The blinkers work and so do the wipers lights etc, just the cruise is non-functional. I have had to replace the ignition in the car because the wires were stretched, so I am wondering if the cruise is also stretched and not connecting properly.
    I am 6'7'' so that is why the ignition had to be replaced, I drive with the tilt wheel almost all the way up!!!
    Thanks alot guys, good forum by the way, been coming here for about 4-5 years, just haven't joined until now!!!!
  • discostu
    • Jul 2005
    • 105
    Did you check for vacuum at the vacuum line? IIRC it's ported vacuum, only present when the throttle is open. Make sure that the diaphragm doesn't have a hole in it and holds vacuum.
    Also check for bad wires or burned/corroded terminals in the connector.
    Once all that's done, then dig into your column and check for bad wires.
    • Bryan921SS
      • Nov 2008
      • 4
      I thought these cars (1996) had electronic cruise, not vacuum....
      • discostu
        • Jul 2005
        • 105
        Oh, you're probably right. Just disregard the vacuum stuff haha.
