Head question
  • Killert
    Atleast it looks cool.
    • Dec 2008
    • 87
    Head question
    I have a 88 Firebird with a 2.8 in it, Will 3.4 (fwd or rwd) Just bolt on? Anything I have to change? Thank you.
    1988 Firebird
    3.4 60*V6
    9 Bolt Rear, 3.27:1, Disk brakes
    Edelbrock 3790 Cam & Lifters
    COMP Cams Magnum Steel Roller Tip Rocker Arms 1414-12
    COMP Cams High Energy Pushrods 7816-12
    COMP Cams Valve Springs 980-12
    PaceSetter Headers 70-1206
  • 923.4v6
    • Feb 2008
    • 182
    the rwd will bolt right on but the 3.4 heads aren't any better. The fwd will also bolt on but requires the intakes also. Its called a hybrid.
    • Killert
      • Dec 2008
      • 87
      So if I get the fwd heads and intake, it should work? and by intake, do you mean everything? or like the intake manifold?
      1988 Firebird
      3.4 60*V6
      • 95Grand-Am
        • 268
        With the fwd head and intake set up you can't use a distributor.
        • 923.4v6
          • Feb 2008
          • 182
          yes you'll have to go to coilpacks here is a diy link http://www.thirdgen.org/techboard/df...ist-motor.html
          • Killert
            • Dec 2008
            • 87
            I think I'll just do the rwd heads, then this summer I'll do a 3.4 block swap
            1988 Firebird
            3.4 60*V6
              Live life 3.7mi at a time
              • 4555
              Don't bother with the iron heads, unless you are modifying them. The iron heads didn't change from about 1986 through 1995.
              • Killert
                • Dec 2008
                • 87
                Really? awh that blows. I thought they had more value duration.
                1988 Firebird
                3.4 60*V6
                  • 4555
                  Valve duration would com from the cam, not the heads.
                  • Killert
                    • Dec 2008
                    • 87
                    Yeah I meant the valves being bigger. I don't know what I was thinking about duration for. and I found a 3.4 out of a 1993 Firebird for 300$ and it will be delivered to my house for 300$ I'm gonna jump on. With only 134K miles pretty good I'd say
                    1988 Firebird
                    3.4 60*V6
                    • 923.4v6
                      • Feb 2008
                      • 182
                      All the fuel injection heads have the bigger valves. If the 3.4 is 300.00 then that isn't to bad, but if its 300+ 300 shipping it's not worth 600 for what power its going to give you.
                        • 4555
                        If you want to use that car to get more power, bolt your 2.8 intake to it, and drop it in your car. The shortblock is a direct fit.
                        • Killert
                          • Dec 2008
                          • 87
                          @ 923.4v6 I actually meant that in was 300$ Delivered.
                          @Forced Firebird I believe thats my plan
                          1988 Firebird
                          3.4 60*V6
                          • 923.4v6
                            • Feb 2008
                            • 182
                            300.00 delivered is a good deal and will give you a good starting point for upgrades.
