throttle bodies
  • Anonymous
    Aaron making stupid comments again....
    • phatkat64
      • May 2004
      • 6
      Originally posted by StudlyCamaro
      the F-body 3.4L TB is 52 mm
      BTW: what is a camaro LS ???????
      OOPS!!! my bad! I just traded a 2001 Impala LS for it!
      I'll have to change that....
      Carmine
      1993 Grand Prix SE, 3.1 TB coolant bypass, 180 T-stat, for starters...
      • phatkat64
        • May 2004
        • 6
        Anyway, 52mm, thanks. Anyone tried the 96-up TB on an F-body??
        Sounds like a good idea if it works!
        Carmine
        • XLR8ING
          Too Stupid To Quit!
          • 268
          Won't work...the F body TB is basically a mirror image to the FWD 3100/3400 TBs.
          Some guys get an adapter welded on the 3.4 to use the LT1 TB.
          Also the F body plenum neck is way to small. We were gonna do a bigger TB for it, but even at 62mm, you can't open the plenum up that much. It's only 62mm on the outside of the neck.
          Franz
          1990 Z24-NA 3.1L
          14.72 @ 92.24 MPH
          14.89 @ 94.92 MPH
          The boost is coming....
          • grandpxigtx
            • Apr 2004
            • 46
            throttle bodies
            know where i can get one?
            Thomas Herring
            • bluebomber
              • May 2004
              • 23
              #21
              I just recently put on a ported Intake manifold and a 3400 TB and I actually notice some decent gain from the mods so I guess 4 mm really does make a difference. I purchased mine from a guy for $60 that was fitted with a 3100 shaft already and appears almost completely new.
              1994 Grand Prix SE 4dr - Brilliant Blue Metallic
              Magnaflow Hi-Flow (And Bashed) Cat
              2.5\" Split Dual Exhaust
              Two Flowmaster 40 \"American Thunder\" Mufflers
              7\" Cone Cold Air Intake
              FFP Poly Motor Mounts
              16.320 @ 83 MPH w/ 2.296 60\'
