Im thinking a Nitrous build is in order
  • project89
    • Sep 2008
    • 247
    i looked around today and what i had for spare parts and this is what i came up with
    block, 3.1/3.4 crank,1 set of rods/3.1 pistons, a old 260 cam and lifters,a gen 2 top end and my other set of ported iron heads.
    i dont have a stock intake for the gen 2 stuff but i do have a custom manifold i built that clears the dizzy. it just needs to be finished
    i also have a wet nitrous setup that i will prolly never use on my turbo motor,its only good for upto 150 shot though.(simple soilinoid change and that can be upgraded to 200-300 shot)
    the 3.1 rwd motor was what 8.9-1 cr ?
    and with the gen 2 stuff it will work out to 11-1 or so
    im not all to familiar with high hp nitrous setups so im unsure of a low compression or high compression build would be in order ill have to look into that
    so i could prolly put this thing together with stuff i have laying around for 300 bucks or so by the time im done with bearings and gaskets.
    not sure though but its deff a very tempting lil side project to do since noone has really built a motor to abuse with nitrous before
    #1 1989 RS - THE L98 AND LT1/LS1 KILLER
    1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
    #2 95 granprix 3100 all stock for now
    ported heads and cam comming soon, megasquirt ems and turbo down the road
  • 1meanz
    • Nov 2007
    • 197
    due eet. lol. deffinatly sounds like it would scream.
    • project89
      • Sep 2008
      • 247
      how much do the 2.8 pistions pop out of the bore when put in a 3.1 crank???
      • project89
        • Sep 2008
        • 247
        im thinking if its not much i could fly cut down a 2.8 pistion to reach a 9.5-1 or 10.0-1 cr
        they are pretty beeffy on the top
        • project89
          • Sep 2008
          • 247
          anyone??
          i knwo the info was posted i just cant find it
