Originally posted by carbon
View Post
200+ WHP?
a decent amount from what I've heard. headers are good for 20hp then ported intakes maybe 5hp and better throttle response.
ohhhh learn something new everyday. i didnt think there was an acual term for that other than hp at the crank lolsigpic
Fender is the best way to go... next to stock air box with K&N dropin. Your MPG may jump around some when you change up your intake, as it takes the car some time to relearn values before you get accurate MPG ratings.Originally posted by Sidewinder View PostNot to thread hijack, but would a fender well intake be better than the stock airbox? One thing I have noticed with the cone filter is that it murdered my gas mileage and I'm either going to run it into the fender or put the stock box back in.
I also had no idea that BHP did not equal WHP... I thought that is how much power you had "at the brakes" so it was the same as WHP... just figured it was a region difference since the only time I see BHP is on foreign things.
Theopia
Enjoy life online.
I (and all the machinists I know) have always used the term "Base Horsepower" when referring to the measurement at the crank as that is your starting point after which all other factors (drive train, rotating assemblies, brake drag, ect) diminish from that initial base reading. It appears now that most guys are using the term "Brake Horsepower" as dynometer is also technically known as a "friction brake".
EDIT: for reference sake, I did manage to get 150 wheel horsepower on a DynoJet dyno with this combo. Little late, I know.Originally posted by Monzsta View PostPorted heads and a tune, as well as a K&n and 2.5" exhaust are all the mods I have. I've been trying to get it to the dyno for a shit and a giggle, but turning a 9.72 in the 1/8 mile with a 3500 lb car probably puts me near 200 whp
Case in point: A stock Series II 3.8 SC usually dyno's 200-240 at the wheels and I can walk them lightly from a roll. From a dig my 3600 stall converter doesn't give them any hope. A GTP is comparable in weight to my Lumina.
I have since sold the 3400 on the floor and now have a 3500 on a stand.
PROGRESS!
Every time I get excited about my project car... I have another kid (2 now, 1 when I posted), I need to find a new job (3rd in 1.5yrs.), need to move for new job (renting out old house), new gutters on the house (not cheap DIY), insurance deductible for new roof (F'ing hail)... and on and on and on... money, money, money...
How important are the wider SBC cam bearings and is it possible do this in my garage or better for a machine shop to install? Special tools?
What exactly is the work needed to run the WOT-Tech Stage 2 cam and LS1 seats (26915 springs) in a 3500? Looks like Ben can do the mods to the seats for $15 at the time of purchase? No other mods to the head or other parts required?
I plan on finding a small port timing set, will the Stage 2 cam take it's toll on the timing set or do you need a wilder cam than this to become a problem?Last edited by carbon; 11-07-2013, 09:58 AM.sigpic
- Ben
I can't speak on the timing set. as far as the cam bearings, you need special tools to install them properly. that being said, I'm sure there's a backwoods way to install them and get the job done. as far as importance, if you already in that deep, do it. if you're just tossing a cam in and hitting the streets, I wouldn't worry about it."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
I bought a SBC bearing tool on eBay fairly cheap a few years ago for a 3400 I was working on. It was a cheap quality one as well, but you get what you pay for and it got the job done, so I didn't complain.
Sent from my HTC One X using Tapatalk-60v6's 2nd Jon M.
I know the stock cam journals are .70 inches wide and stock cam bearings are .61-.62 inches wide(non calibrated digital caliper) but the stock cam bearings don't cover the whole cam journal by almost a tenth of an inch, I know when my cam was on the verge of snapping in half(I still have the old cam) the journals were grooved in like the bearings were grinding into them.
I don't know how wide the SBC cam bearings are though, I blamed my cam wiping out on poor oiling from the 96 block casting valleys and slow coolant ingestion over its 16 year life. I know the stock replacement cam bearings have been revised but I don't know what or why they were revised, they are pricey compared to SBC cam bearing though.
I would stay with stock cam bearings but that's just me, you'll need a SBC cam install tool that is more expensive then having a machine shop install unless you plan on changing out cam bearings in the future. Just make sure that the oiling holes are facing the right direction if you have a machine shop do it.1997 Chevy Lumina LS- SOLD
Mods:3400 cylinder heads, 01 upper & lower intake, 56mm throttle body, 22.5lbs injectors w/ 55psi regulator, 1' 3/8" thick radiator, tuned with lower fan temps by wot-tech
2010 Chevy Impala LT
Mods: LGD swap, 3.29 standard duty differential, 33 37 drive sprockets, Don Rome brackets, front and rear GMPP strut tower braces, GMPP 22mm front sway bar, GMPP 19mm rear sway bar and tune from Over Kill Motorsports
Cause that's what Ben sells in his stage two cam kit... no other reason. Other than fit is there a benefit one way or the other?Originally posted by caffeine View PostWhy run the 26915 springs? The 26986 springs drop right in with no changes and I've been running them with the stock '06 3500 timing chain for 10,000 kms.sigpic
- Ben
Yeah, I looked it up on YouTube... apparently you only make good howto videos if you're working on a V8...Originally posted by ericjon262 View PostI can't speak on the timing set. as far as the cam bearings, you need special tools to install them properly. that being said, I'm sure there's a backwoods way to install them and get the job done. as far as importance, if you already in that deep, do it. if you're just tossing a cam in and hitting the streets, I wouldn't worry about it.
- Ben
IIRC the 26986 can handle a bit more lift but have a lower RPM limit. For stage two I would think they would be fine. I rev mine to 6800 on a regular basis, sometimes 7000.Originally posted by carbon View PostCause that's what Ben sells in his stage two cam kit... no other reason. Other than fit is there a benefit one way or the other?'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
'86 Fiero, 3500, 4-speed
True dat... Or an import guy. Was tempted to say ricer, but there are a few that actually build for performance, not just throw a fart pipe on their car.Originally posted by carbon View PostYeah, I looked it up on YouTube... apparently you only make good howto videos if you're working on a V8...
