Active Fuel Management Disable
  • aleroguy85
    • Nov 2008
    • 6
    Hi, does anyone know if you can turn off the AFM in something like the LS4 motor? I assume you would have to tune the ecm to have it disabled but I don't know what else. Thanks.
  • TiredGXP
    • Jun 2008
    • 107
    Tuning software such as HPTuners can disable AFM/DOD functions - It's just a flag on the Engine---> Fuel Control---> COT,Lean Cruise screen for the LS4.
    I suppose you could physically disable it by disconnecting the solenoids that supply to the AFM/DOD lifters. These solenoids are designed to fail in the closed position, so the lifters can't collapse. Probably throw a few codes though.
      Then you should be able to swap to normal lifters correct?
      • TiredGXP
        • Jun 2008
        • 107
        Yeah, but on the LS4 you need new lifter retainer trays too.
          You could swap that from LS1 though right?
          • TiredGXP
            • Jun 2008
            • 107
            Yup.
