another piston question
  • bob442
    Show Me Your KITS!
    • Nov 2008
    • 1305
    what is an ideal compression ratio for a N/A motor, and who offers the pistons for that, and what are the other ways to accomplish the ratio.
    I've read in posts that someone used camaro head gaskets, but I got confused as to if it was for a iron heads or not, do I want high compression 9:1? or 11:1?, what have some of you guys done to establish some good numbers? and who should I get what internals from, what pistons will hold up the best, and not cost 1000$
    I'm starting to get fustraited with reading topics all the time, and not getting the answer I need, so i'm just going to ask, I want to get a cam for mid and high rpm power, possibly getting a no2 kit, wet or dry, I don't even know, I'm rebuilding a whole 3400 motor, and porting and polishing the heads, upper and lower intakes, and possibly getting the 3500 upper intake. are the pistons from summit reasonable for this kind of application? the motor will be going in a beretta with an auto trans and obdii wiring and proper tuning when everything gets to that stage, i'm willing to spend some money, but not dropping more than $2500 on just the motor and internals, i'm doing all the assembally and as much as I can myself with help. someone point me somewhere.
    Just name it atleast and i'll source it. thanks.
    Bob
  • Alxsmt
    that one guy
    • Feb 2007
    • 725
    camaro 3.4 pistons will gain you 11.5:1 compression from the top of my head (could be wrong) and dohc 3.4 pistons will get you in the 13:1 range (again from the top of my head)
    i wanted 10.5:1, wiseco decited they didnt want to make mine even after i sent them a sample of the combustion chamber mounted to a piston like they wanted... ended up going with je. for any custom piston they need every little volume measurement, and size etc. i think mine were in the 850 $900 range with rings and pins
    • johnnymossville
      • Jul 2007
      • 255
      '93/'95 3.4 iron head pistons in a 3400 block with 3500 heads is 11.56:1 which is what I am running. The same pistons with 3400 heads will be a little over 12:1 as the 3400 combustion chamber is a little smaller than tha 3500s. The SpeedPro/Sealed Power pistons from Summit at around $30 a piece are hypereutectic pistons which have a higher silicon content making the suitable for lower boost levels or small nitros shots, and are also the pistons that I am running. The stock rods are forged and good enough for 300+ hp and 7k rpm. I know that a bunch of us have done this. So with my build I run 93 octane Shell gasoline and drove it every day to work and around town no matter what the temp was outside. Can't wait to get my engine in my Monte. Oh yea, I have a set of S&S headers modded to fit that Beretta if your interested.
      • bob442
        Show Me Your KITS!
        • Nov 2008
        • 1305
        thank you very much john, now i have anther question, where can i get the factory specs on the internet for the 3400 3500 sfi, and 3.4 camaro motor, and 3.4 dohc motor, so maybe i could figure out something here for a higher compression or is that as high as i could go with ordering from summit...
        • bob442
          Show Me Your KITS!
          • Nov 2008
          • 1305
          found it!
          Make CHEVROLET
          Engine Type V6
          Liter 3.4
          CID 207
          Engine Size 3.4L/207
          Beginning Year 1996
          Ending Year 2004
          Engine Family GM V6
          Rod Length 5.700 in.
          Stroke 3.310 in.
          • sprucegagt
            Old School KI
            • May 2005
            • 703
            I wouldn't necessarily trust the information on Summit. Instead just look at the left hand side of this page under "Motor Articles -> Specifications". They are the factory specs.
            Your local OBDII moderator
            2000 Grand Am GT w/ WOT parts
            • bob442
              Show Me Your KITS!
              • Nov 2008
              • 1305
              found more, but for a camaro
              L32 3.4 Liter V6 (207 Cu Inch)
              60 Degree front Longitudinal, OHV
              Bore:92.029 mm
              Stroke 84 mm
              Cast Iron block
              Firing order 1-2-3-4-5-6
              L (Front to Back ) 2-4-6
              R 1-3-5
              Horsepower:160
              200 ft/lbs of torque
              Knock Sensor Located Right Side Center of Block
              Compression Ratio 9.0:1
              Fuel: 87 octane
              Fuel Tank Capacity= 15.5 Gallons
              Total Engine Mass : 452 Lbs (Auto) 492.8 Lbs (Manual)
              Sequential Fuel Injection
              Computer Controlled Air/Fuel Ratio
              Electronic Pulse (injection)
              Cast Iron Heads (29 Lbs each)
              Aluminum Intake Manifolds
              Normal Oil Pressure:50-65 psi
              • bob442
                Show Me Your KITS!
                • Nov 2008
                • 1305
                some more info,
                • johnnymossville
                  • Jul 2007
                  • 255
                  The pistons I used are for the 3.4L iron head Camaro 1993/95. These produce 11.56:1 cr with the 3500 heads and that is the highest that I wanted to run with 93 octane pump gas. If you use the 3.4 DOHC pistons with the 3500 heads you will end up a little over 12.5:1, and I believe over 13:1 with 3400 heads. On the left side of the screen you will also see the CR Calculator which should give you very accurate numbers.
                  • bob442
                    Show Me Your KITS!
                    • Nov 2008
                    • 1305
                    thank you sir. much appriciated, i'm now looking into how the hell i could use a 3500 crank and 5.9" rods, sourcing all options. these motors are pretty confusing to keep track of everything, i got a note pad going. lol
                      • 9191
                      For all the internal info (bore, stroke, head chamber size, etc), use the site CR Calculator (on the left sidebar). You'll be able to get everything you need to determine different CR for different combinations.
                      • bob442
                        Show Me Your KITS!
                        • Nov 2008
                        • 1305
                        well i understand that, but, do all the pistons have the same pin size? same rod size?
                          • 9191
                          Look in the Specifications section of the site (like Andy mentioned a few posts back) and all that info is there.
                            Live life 3.7mi at a time
                            • 4555
                            Rods didn't change from the 2.8 iron head up through the 3400, after that they changed to 5.9" and 2.249" big end.
                            • sprucegagt
                              Old School KI
                              • May 2005
                              • 703
                              You sure about that? I thought I remembered reading here that they were really 5.827" rods.
                              As for using true 5.9" rods they can be done, but only with custom pistons.
