cam help pls
  • i8sum2
    • Feb 2009
    • 21
    cam help pls
    i have this cam nib was going for n/a now im going for turbo setup was woundering if this would work or if i need to change cams? i am also using 1.6 rockers
    Grind Advertised Duration Gross Lift
    Duration Lobe Center @ .050" 1.5 / 1.5
    Intake Exhaust Intake Exhaust Intake Exhaust
    290HDP 290° 298° 226° 234° .470" .492"
    108°
  • i8sum2
    • Feb 2009
    • 21
    damn it changed the way i typed it out
    • i8sum2
      • Feb 2009
      • 21
      grind lobe center 290HDP 108°
      advertised duration 290° 298°
      duration @ .050* 226° 234°
      gross lift with 1.5 .470" .492"
