1/2 fill vs tall fill
  • montess408
    • May 2006
    • 391
    niice! can't wait to see the rest of the build .and see if it can run on obd1.
    also in for pics !!
    • Nightingale
      • Apr 2005
      • 259
      Anyone else hear about the possibility of block filler ruining the water pump? I have heard some people "seal" the filler to prevent this potential problem, but with what is the question(block sealer aka stop leak). I can see how the filler could be a potential problem, as the water moves over the filler it will probably errode some of it, which will end up chewing up the water pump. It could also potentially be that minerals are leeched out into the coolant considering this is concrete based product, which could buildup inside the pump as well.
      98 camaro swapping in lz9 th400 setup
      LZ9 specs: (Subject to Change work in progress)
      4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
