Higher compression head gaskets for 2.8
  • Tonglebeak
    • Feb 2007
    • 154
    I've heard that using a 2.8 camaro headgasket will offer an increase in compression vs the headgasket for my ciera (aluminum). Is this true? Is the 2.8 camaro the correct gasket to get to safely bump up compression? I won't have to worry about piston into valve issues will I?
    correct, the .040" gaskets for the Camaro iron heads when used on the 2.8 FWD Aluminum head will bump up the compression to 9.24:1.
    Lots of people have done this with no problems.
    • Tonglebeak
      • Feb 2007
      • 154
      So I need to get the iron head 2.8 gaskets? Which years did that cover?
      • gsEnterpries
        Let's go off tonight
        • Mar 2009
        • 118
        Yes you need the iron head, head gaskets. You can get these from 1982-1988 Camaros w/ 2.8l V6
        -Gary
        -Gary
        1983 Camaro 2.8l not much done yet
        1999 Chevy Prizm - typical bolt-ons
