2.8 pistons in 3.1
  • berniejayd
    • Feb 2009
    • 11
    2.8 pistons in 3.1
    Has anyone used the 2.8 flat top pistons in a 3.1. I have a 3.1 and wish to increase compression and otherwise I would need custom pistons. I know the 2.8 pistons will need to be cut down...is there enough thickness?
    Thank you,
    Bernie
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    In my "engine rebuild" thread there was discussion about this process. It can be done. How much compression are you looking for? Is this an iron head or aluminum head motor?
    • berniejayd
      • Feb 2009
      • 11
      pistons 2.8 to 3.1
      I have also read the discussion, but as far as I could tell no one has acually used the 2.8 pistons.. there is an issue about if there is enough thickness in top of piston to adj deck (2.8 pistons would be taller).
      I'm looking for neiborhood of 11:1 compression and I also know that I would need to adj chamber vol for this compression. I'm just trying to avoid having custom pistons made.
      This engine is for a 1200 lbs sports racer..
      I have two engines and I do not wish to buy any others. One engine is a 3.4, the other is a late 3.1. I can use the 3.4 with the 3.1 al heads. With this combination I would have to use the Gen 2 cam with the flat tappets. If I use the 3.1 engine I need to increase the compression so I would have to use other pistons. If I do this engine I can use the roller cam.
      So do I use a larger displacement engine with the flat tappet cam or do I use a smaller displacement engine with a roller cam (likely more available cam choices).
      With either engine I am looking for high rpm not low end torque.
      Bernie
      • project89
        • Sep 2008
        • 247
        if u look in his thread again i posted all the measurements of how thick the pistion is before cutting and after for each desired cr.
        i even have the picton i cut in half sitting nexto me ill snap some pics in a lil bit for u so u can see
        #1 1989 RS - THE L98 AND LT1/LS1 KILLER
        1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
        #2 95 granprix 3100 all stock for now
        ported heads and cam comming soon, megasquirt ems and turbo down the road
        • berniejayd
          • Feb 2009
          • 11
          Could tell me how to get to your post about the 2.8 piston.
          bernie
          • project89
            • Sep 2008
            • 247
            http://60degreev6.com/forum/f96/engine-rebuild-t42465
            • berniejayd
              • Feb 2009
              • 11
              Thank you "project 89"
              Bernie
