Block Milling
  • gsEnterpries
    Let's go off tonight
    • Mar 2009
    • 118
    Block Milling
    I wanted to know if milling my stock 2.8l LO block .027" was a good idea.
    Reasoning behind this, raise the compression a little more. The piston deck clearance is .047", after milling, it will be .020". Would this cause any problems. If not can I also mill .010" off my heads with out any problems or is this just a stupid idea to do to the heads.
    If anybody has done it or has any info would be great.
    Thanks
    -Gary
    -Gary
    1983 Camaro 2.8l not much done yet
    1999 Chevy Prizm - typical bolt-ons
    i believe that the biggest problem this will cause is that the valetrain geometry will be.........off?
    • gsEnterpries
      • Mar 2009
      • 118
      The whole idea itself or the just the heads?
      -Gary
      -Gary
        -Gary
        don't quote me on this but if you mill the block or heads, its essentially making your pushrods longer as well, meaning you'll need new, custom-length pushrods. it might bolt together and run but it wont be "ideal".
        theres other members here who know a lot more than me about the subject but that should help a little.
        • gsEnterpries
          • Mar 2009
          • 118
          Thank you. The pushrods, those I forgot about, I have built way to many jap motors in my life and they don't have pushrods, so what you said makes perfect sense.
          -Gary
          -Gary
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            Your easier route is to get HO pistons which will solve your compression problem. Milling the deck that amount may be a little much. I got about 0.014 milled off mine. Milling is not that critical to the valvetrain since it is adjustable on the older motors. As long as you keep it within reason
            • gsEnterpries
              • Mar 2009
              • 118
              Where do I get HO pistons every where I look I can't find any.
              -Gary
              -Gary
                -Gary
                i'm gonna take a stab at it and say............. fiero pistons??? i know they had a better cam than any other 2.8, maybe the same is true for pistons?
                • gsEnterpries
                  • Mar 2009
                  • 118
                  so your telling me find out what car had a HO 2.8l and buy pistons for that. If that is the case that would explain why I could not find any in the aftermarket. Thanks again.
                  -Gary
                  -Gary
                  • geoffinbc
                    • 5831
                    If you just order from any EFI 2.8L with iron heads it will have the 8.9:1 compression pistons. So say a 1993 S-10
                    • gsEnterpries
                      • Mar 2009
                      • 118
                      sweet deal
                      -Gary
                      -Gary
