lifter mods
  • gectek
    Banned
    • Aug 2006
    • 1472
    depends on the RPMs you are going to pull. lower than around 6k i would say no dont do it.
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      poop.
      • 923.4v6
        • Feb 2008
        • 182
        Its the 272 which is going to 6200-1 6000-2 and 5800 3rd gears.
        • gectek
          Banned
          • Aug 2006
          • 1472
          stay with the stockers...they are good enough. you would need a bigger cam than that imo to justify it. or a higher rpm limit
          • MidnightriderZ24
            • Jan 2005
            • 699
            id recommend it anways, our lifters are junk factory.
            [SIGPIC]
            12.268@117... 11's to come!
            • Driver_10
              • Jul 2006
              • 487
              #21
              Ill be spinning a touch faster.
              7200 rpms at all shifts with 6500 peak power band and comp-cams #122 springs. Safe redline of 7500rpms. Absolute red-line of 8000rpms
              If thier are any doubts that this is is feasable with modded hydraulic lifters, let me know now. Otherwise Im sticking a set of solid lifters in the motor.
              Sorry about the thread-jack, but it seems like a good opportunity to get an answer.
              • gectek
                Banned
                • Aug 2006
                • 1472
                #22
                solid lifters will give you more power in the upper rpms with a small sacrifice down low.
                • MidnightriderZ24
                  • Jan 2005
                  • 699
                  #23
                  how will u adjust for lash on solid lifters?
                  [SIGPIC]
                  • gectek
                    Banned
                    • Aug 2006
                    • 1472
                    #24
                    adjustable rocker arms or adjustable pushrods, or the correct length pushrods.
                    • torq455
                      If I only had money!!!
                      • Dec 2003
                      • 1615
                      #25
                      you'd have to have adjustable rockers for solid lifters. they wear over time, and tightening them down more is how you keep the appropriate clearance.
                      Andy
                      fastest 1/8: 10.19@ 67.17
                      fastest 1/4: 16.16@ 82.70
                      • Driver_10
                        • Jul 2006
                        • 487
                        #26
                        I was intending on using Summit 1.6:1 sbc adjustable roller-rockers. Since Im using a stage-3, off-the shelf WOT-TECH 3400 turbo cam, I dont think that there will be a need for special-length push-rods.
                        If I can pull off 7500rpms without valve float on modded hydro lifters
                        then Id rather take that route. If not, then Ill use my solid lifters.
                          you still should measure for correct pushrod length. Your rocker geometry is going to be off and with spinning the RPM's you are planning i wouldn't risk anything.
                          I thought SBC rockers wouldn't work for some reason....
                          I seriously doubt you'll float the valves with good springs and the modified lifters, With solids you might make a tad more HP but having to regularly pull the valve covers is what turned me off from them.
                          • torq455
                            • Dec 2003
                            • 1615
                            #28
                            SBC rockers won't work, although, i have a strong theory that SBC with center bolt rocker covers would work. my Dad had a set of 1.6 roller tips and they looked very much like mine.
                            rule of thumb: if you change the cam, you change the pushrods.
                            Andy
                            • gectek
                              Banned
                              • Aug 2006
                              • 1472
                              #29
                              i have tried the narrow body ones before on my heads...they wont work right. the tip is too large and hits the retainer instead of the valve stem unless you use a +.050 retainer/lock. I tried both the self aligning and the non and both are too wide.
                              • torq455
                                • Dec 2003
                                • 1615
                                #30
                                must be just enough to cause problems. they looked the same. i wasn't able to give that a try. good to know.
                                Andy
