i need headers for a 3.1L firebird
  • WS6LOVE
    coulda hada V8
    • Dec 2007
    • 54
    i can find them for a 2.8 firebird, but not a 3.1L. i need them soon, as the bolts are randomly breaking in half and falling out of my stock manifolds. yea, thats right. they're just that rusted. this is my daily driver now, so i cant afford for it to go down. and i cant be spending $400 on a set of headers right now. im still planning on yanking this engine for a 3.4 anyway, but will be using the 3.1 in other projects.
    i was thinking these would work:
    http://www.jegs.com/i/Pace+Setter/766/70-1206/10002/-1
    any suggestions?
    sigpic<---SERIOUS cornering now
    300NAhp@the wheels....eventually
    http://www.cardomain.com/id/royal455<--new pics of the engine pull on the '94 firebird's page
    http://www.myspace.com/drfeelgood_80
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Check Edelbrock and Hedman. But if your bolts are breaking then why not just get new bolts from GM. I bought them for my Trooper. They have the correct ones with the studs on the head of the bolt for mounting accessories.
    • WS6LOVE
      coulda hada V8
      • Dec 2007
      • 54
      i would, but i'd rather just get headers. they arent leaking too bad right now. just bad enough to justify headers in my mind
      do you know what part #s i should be looking for from those 2? i've searched jegs and summit and cant find anything but those pacesetters.
      thanks for the help
        2.8, 3.1 and 3.4 all have the same heads (RWD). The 2.8 headers will fit the 3.1 and 3.4 just fine.
        • WS6LOVE
          coulda hada V8
          • Dec 2007
          • 54
          That's what I thought. Thanks so much
          • Killert
            Atleast it looks cool.
            • Dec 2008
            • 87
            Partstrain.com P#P40701206
            Just bought a set.
            Many people on the Third Gen website I'm on use these. I'll be installing mine soon hopefully or selling the car.
            1988 Firebird
            3.4 60*V6
            9 Bolt Rear, 3.27:1, Disk brakes
            Edelbrock 3790 Cam & Lifters
            COMP Cams Magnum Steel Roller Tip Rocker Arms 1414-12
            COMP Cams High Energy Pushrods 7816-12
            COMP Cams Valve Springs 980-12
            PaceSetter Headers 70-1206
            • 923.4v6
              • Feb 2008
              • 182
              pacesetter headers will work, but I heard that the smog pump will have to be removed on the 3.1's, not sure because mine was already removed when I bought them. I'm thinking the 2.8's didn't have a smog pump and thats why there only advertised for them.
              • gsEnterpries
                Let's go off tonight
                • Mar 2009
                • 118
                The 2.8l's did come with smog pumps, atleast mine did any way.
                -Gary
                -Gary
                1983 Camaro 2.8l not much done yet
                1999 Chevy Prizm - typical bolt-ons
                • rallen
                  93 Gmc Sonoma
                  • Mar 2009
                  • 26
                  93 S-10 2.8s have smog pumps
                  would F body headers work on S-10s? I need something better than the stock manifolds too. I'm missing most of my bolts too! And I wouldnt want to go through the trouble of removing the stock stuff just to put them back on. And those GM bolts are expensive, or I'm to cheap....
                  • rallen
                    93 Gmc Sonoma
                    • Mar 2009
                    • 26
                    Or are there better manifolds out there? Are the 3.4 manifolds any better?
                    • WS6LOVE
                      coulda hada V8
                      • Dec 2007
                      • 54
                      My 3.1 has the smog pump on it still, but its not hooked up to anything. If I knew how to route the belt correctly, I would remove it. I already have the a/c compressor off too. So if anyone has a routing diagram lemme know. I really wanna get rid of that smog pump.
                      And yes, my '83 firebird with its 2.8 also had a smog pump.
                      Killert, lemme know how you like your headers after you install them. But don't sell the car! Its a firebird. And your firebird loves you haha
                      • 923.4v6
                        • Feb 2008
                        • 182
                        I just took mine off got a shorter belt and it ran straight from the alt. to the crank. I heard of some saying they had belt slippage but mine didn't have any. If the 2.8's have the pump then you may not have to remove it, I already had removed mine when I bought the headers.
                        • WS6LOVE
                          coulda hada V8
                          • Dec 2007
                          • 54
                          I think when I tried mine I was having trouble making sure the water pump was spinning the right way. But I can't remember.
                          • geoffinbc
                            • 5831
                            No they wont work. But Hedman and Edelbrock both sell S-10 headers.
                            • 923.4v6
                              • Feb 2008
                              • 182
                              The water pump will still have the same wrap, it will just go straight to the crank instead of to the smog pump then to the crank.
