Steel pan only, as the mounting of the aluminum pan is different.
new guy, 3.4L hibred build
Originally posted by bszopi View PostSteel pan only, as the mounting of the aluminum pan is different.
Quite different....
as far as the pulleys and front drive setup, i plan to use the stuff from my 2.8 thats being pulled for the 3.4 (87 s10). it looks like ill need to make some spacers, etc and i dunno if the AC compressor will clear. other than that, looks good and easy.
use the timing cover, oil pan, water pump, accessories and brackets from the S10
i know ive seen a few other swaps like this, and i seem to recall that the brackes required a new hole being drilled somewhere as well.
michael
The brackets will work with the holes enlarged and/or re-drilled on the serp belt drive. Only problem I had was the alternator was close to the TB and may need some addressing.
