1.6 roller rockers
  • grandpxigtx
    • Apr 2004
    • 46
    1.6 roller rockers
    what do i need to 2 do to install them on a 95 3100/v6 stock cam?
    Thomas Herring
    • 9191
    Are you talking about the stock roller rockers? If you heads have the notches for the factory rocker pedestals, then all you have to do is bolt them on. If your heads don't have the notches, then you are SOL. Basically need to get heads with roller rockers stock.
    If you are talking aftermarket, that's a different story...
    As far as working with the stock cam, there is nothing you have to do.
    • torq455
      If I only had money!!!
      • 1615
      aftermarket is a different story, but no too bad to do.
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
      • grandpxigtx
        • Apr 2004
        • 46
        i have the magnaum 1.6 roller rockers & and if i cant use them then what car can i use to get the 1.6 stock rockers from & what notches and can the valve covers fit a 3100 from a 93-94 3.1?
        Thomas Herring
          3100's all had 1.6:1 ratio stock BTW.
          The 96+ 3100's had roller fulcrum rockers (not roller tip though). To use them your heads must have the notches where the rocker pedestal bolts to.
          Any 3100/3400/3500 (lx9) valve cover will bolt up. The older year 3.1.mpfi I'm not sure. With a some work they might, but you got the coolant tube etc possibly to work around.
            your car has 1.6 rockers already.
            the ones you bought, are they Magnum roller tips?
            • grandpxigtx
              • Apr 2004
              • 46
              there magnum roller rockers 1.6 ( i dont understand about the notches do u have a photo or where can i go to see them( i have the heads off and clean ported ready 2 go back on) asap
              Thomas Herring
                • 9191
                You only need to worry about the notches if you are planning on running the stock roller (fulcrum) rockers.
                • grandpxigtx
                  • Apr 2004
                  • 46
                  dude i dont have a clue?
                  Thomas Herring
                    • 9191
                    Ok, we'll start from the beginning...
                    You currently have stock 95 heads and you want to install a set of Comp Magnum roller-tip rockers in place of the stock, correct? If so, it should be just a simple bolt-on install. You really won't be gaining much with a roller tip rocker, other than a more accurate ratio and a very slight reduction in friction.
                    • grandpxigtx
                      • Apr 2004
                      • 46
                      so whats the best way to go cause the last time i did that diret bolt in i hjad to replace the motor
                      Thomas Herring
                        you installed rockers and because of them you had to replace the entire motor? you want to explain that a little more...
                        • grandpxigtx
                          • Apr 2004
                          • 46
                          they said i had bent my pushrod/or rods so i scrap the whole motor & got a nother one (iforgot what yr 3100) and started all over again i think they didnt know what they were doing.
                          Thomas Herring
                          • torq455
                            • 1615
                            he said last time he had a bolt on. you already have 1.6 rockers on the heads. you won't notice the roller tips should you put them on. i wouldn't waste the time and money to install a roller tip without a ratio increase. if you had a 1.5 ratio, like i did, it's very much worth it to swap them.
                            did you know there are different length pushrods at the time? you didn't have to scrap the motor from bent pushrods.
                            Andy
                            • grandpxigtx
                              • Apr 2004
                              • 46
                              so keep the heads they i got them (they been sitting for about 2 yrs ported/polish same everything else)?
                              Thomas Herring
