IIRC... The CPS signal goes directly to the ECM and the ECM sends a signal to the coils. Same setup on the LZ engines and the new Chinese 3400s. Different CPS signals but the same concept.
3500 coils? better than previous?
MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
http://www.tcemotorsports.com
3.1mpfi etc ICM and coils are same thing as 3100/3400 ... so if you have those...
Edit:, you probably had a iron head engine with a dizzy.. nevermind...sigpic
If you are using a haltech this might apply http://www.teglerizer.com/fi/megasqu...on_module.html ,it's for megasquirt but it might work.
yea, i printed out wiring diagrams of the 04 malibu, the CPS goes directly to the ecu, then theres 2 "data" lines that come from the ecu to the coils.. then a line
No, its ETC (drive by wire) like pretty much all the new GM motors now. I don't think GM has a single cable driven engine anymore. The 2009 intake has been modified to the larger bore too. Plus that upper intake even the 65mm 2005-2008 ones won't clear most hoods as the TB neck goes right on top of the center of it. Strange they still list the engine as 185hp... How can a LA1 3400 with a 56mm TB make the same power as one with a 77mm TB... LOL why do they need that large of a TB?? Strange....sigpic
77mm does sound a bit large over the 56mm cable TB, does it open fully? maybe its designed to only open like 70% or something?
Who knows. The 65mm ETC one opens fully. I would say it would because the document mentioned the intake manifold was modified to 77mm as well. If it didn't open all the way they wouldn't bother with that.sigpic
