3.1 headbolts 3400
  • mickaz
    • Aug 2004
    • 350
    3.1 headbolts 3400
    hi
    rockauto sent me headbolts for a 91 to 94 3.1 v6. are they the same a the 3500 and 3400?
    Mike 60degree addict.
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Felpro sells both so cross check the part numbers. If they are different I would not use them. The length and material may be different.
    • WrathOfSocrus
      • Jan 2008
      • 318
      If you click on the part numbers on rock auto it shows the cross reference. Depending on application they fit cars ranging from '87 to '05. They should be exactly the same as the 3400 bolts.
        all gen2 and gen3 '660's use the same headbolts.
        • ghrarhg
          • May 2005
          • 215
          I had different part numbers for my 88 2.8 head bolts compared to the 3x00. It's due to how the upper motor mount attaches to the block on the passenger side. The one head bolt has a pin that threads into it for the mount to attach to. The other 15 bolts should be interchangeable.
            yah, i thought of that.. some of them had that 1 different bolt. Either way, the rest are the same.
