hybrid build questions.
  • brianfulcher
    • Jun 2009
    • 1
    Hey guys Im currently looking at either building a hybrid 3400/3500 turbo or na engine. here is what mp performace priced the build to me at.
    The cost on the build and all materials would be $5,250. This includes the following: Prepped 3400 Block and crankCustom Turbo Camshaft and pushrodsForged Pistons with Boost Rings65mm Billet Throttle BodyCompetition Ported 3400 Upper IntakeCompetition Ported 3500 Lower IntakeTiming SetPorted 3500 HeadsMain Bearingslifterscam bearingsRod BearingsrockersgasketsAssembly The motor will be good to rev to ~6500-7000 RPM and will easily handle 15psi which is more than what you plan to run compression on the motor will be roughly 9:1 which will make it work very well with boost as well as give decent MPG when not in boost. I know the price may seem high but this is because we have to supply everything... if you have any parts on hand like head/manifold cores or the 3400 block and or crank you plan to use let me know and I can adjust pricing as needed. The only parts not included in the build are the crank damper and and flywheel as these parts are not needed for the actual build since the motor is internally balanced and we will be performing a performance balance on the motor before assembly. The build will take approximately 2-3 business weeks to complete due to cleaning, machining, and painting of the engine block. Also the motor will need to be picked up unless you are able to arrange shipping. Please let me know if everything looks ok to you and if so I will send you an invoice for the build asap. If you have any questions at all please feel free to ask.
    I could assemble it myself, but if the parts/porting cost close to the 5250, then i would rather them build it.
    what do you guys think.
  • Firehawk94
    Fbody Fiend
    • May 2009
    • 179
    By a V8 car with the 5250 (Z28, Trans am, Mustang GT) and get the same results and a new ride. Nah for real though that sounds a bit steep to me. I recently had a 2.5L 4cyl. from a Dakota rebuilt for 800 bucks at the local machine shop and that was including a new rotating assembly. Just save your wallet the heartache and by a Trans am!!!
    94 Firebird 3.4 DD
    252000mi. All original
    • stewartfn18
      • Aug 2008
      • 114
      lulz^^^so true. thats what i did.
      OP, 1. Learn to use puctuation and 2., 5 grand IS a bit steep for all that. ive sank about 2500 into mine, and im done with this car engine wise when this liitle project is done.
      MODS: DS CAI, TCE 65 mm tb, TCE AFPR, TCE LS lifter springs, WOT ported UIM and LIM, 3500 heads, comp cams valve springs locks and retainers, 1393 grind cam, S&S headers, custom 2.5 in catback, flowmaster 80 series , no rez, and to top it all off, an MPR tune. Among misc gauges and appearence things
        Live life 3.7mi at a time
        • 4555
        I've got about $2-3k in my twin turbo 3.4/3500 hybrid going in my Firebird, all done at my shop by me personally.
        Are you trying to sell us a motor that hasn't been built/tested?
          damn, i didn't know you had twin haridryers....
          and WHAT is that evil piece of technological trickery?
            • 4555
            That is my dual-power Willems chip burner. It will burn/read just about any chip you can throw at it
              and i cheaped out to get a BURN2...
                • 4555
                Hmmm. The Wilems was $50
                  mines simpler....
