3500 heads on 3400 stock
  • Sleeper3400
    • Nov 2008
    • 18
    Hi, I have a 3400 1999 in my Cavalier that i'm presently rebuilding and i also have a complete 3500 LX9, and I montana 2000 that I bougth for the newer intakes.
    What i was originaly planing to do was to keep my engine stock with the 2000 intake style and put an Aurore LX5 throttle body. Now i'm thinking to get the 3500 heads with the lower 3500 intake and the 3400 upper intake from my montana, also with aurora TB and probably with and injectors upgrade.
    My question is that with the hybrid the compression will drop to 9.1:1, so will I can gain something with this combo or due to the lower compression I will lost gain that the 3500 heads can give me?
    Cavalier 1999
    3400 from an Alero
    Clutchmaster Stage 3
    Accel coils
    2.5" exhaust with only one Cherry Bomb Vortex
    Hybrid on the way
    You will still gain some over the stock 3400 setup. The 3500 heads flow much better than stock 3400 heads. plus your only going down .4 points of compression that's not a huge amount.
      Use the 3500 upper too. And you won't have to port out the neck for the TB too that way!
      • geldartb
        The Situation
        • May 2004
        • 1994
        ahh porting the neck isnt that hard. its the porting the other 6 openings thats the time killer.
        99 Grand Am GT
        1357 cam 227 233 .050 dur
        515 515 lift 112 lsa
          Even better reason to use the 3500 upper... No runners just open up the thin openings. Takes no time at all!
          • Sleeper3400
            • Nov 2008
            • 18
            My interest for keeping the 3400 UIM is for the Throttle Body (no need of an adapter) and also for all the other modification need with the 3500 UIM. We cannot forget to mention that the 3500 UIM is very ugly, lol. Sorry for my english i'm from Québec, Canada.
            Cavalier 1999
            3400 from an Alero
            Accel coils
            Hybrid on the way
              Pretty doesn't win races, that ugly UIM is worth 5-10 HP and a much better RPM range over the 3400 one.
              a little black paint makes it look pretty decent, or if you have enough clearance you can use the plastic engine cover.
              • gar70614
                • Oct 2008
                • 330
                why not put in the whole 3500. thats wat im puttin in my 99 z24
                • MY91GT(Z)
                  • Sep 2006
                  • 387
                  i painted my ol 3500 uim primer grey and i think it looked tits but to each is their own and i would reccommend the complete 3500 if i were you and get some headers and im sure you'll crack 12s with ease on that 100 shot of noz
