2.8 Timing Curve Question(s)
  • 2.8 914
    • Jul 2009
    • 5
    Hello to all. I have a 1974 Porsche 914 that has a 2.8 motor which I installed. It is a 1982 Citation x11 engine. The bore and stroke are standard and the CR is 8.9:1. Cam is a Crower solid lifter SPL grind #D-4046. Rocker Ratio is 1.50:1. Manifold is a Edelbrock Torker 2 and carb is a Holley 390 4barrell. Engine has modified S10 Headman headers. Mallory ignition with a non-computer Hei distributor. The engine bolts up to a stock 914 trans. with the help of an adapter plate. I am not the engine builder and am not very good at getting engines to run well, but I am trying. The engine sounds fantastic without a load on it and doesn't run too badly, but it just isn't right. I think the timing curve is all screwed up and when I add vacuum advance, it runs worse. Can someone please suggest a correct advance curve that I can try and some info. on Hei distributors and which one should be used for this engine? Thanks in advance for any info. Pete
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Set base timing at 10* BTDC to start (might vary because of the cam and mods) and have all advance in by 1800~2000 RPM. Total advance (again depending on what it likes) should be in the neighborhood of 34~38 *BTDC
      1800-2000? damn thats early, at least compared to SBCs...
      • geoffinbc
        • 5831
        It is but if you look at performance distributors on the market they are typically all in by 2000. Hotter cams will require more advance as well.
        • 2.8 914
          • Jul 2009
          • 5
          I set the initial timing to 10-11 BTDC last night and then checked to see what it was doing @2000 rpm and it was only at 21. ( this was done with the vac adv disconnected) Does this mean that my centrifical advance springs need to be changed? Lighter or heavier? I know they can be different springs at the same time. Thanks
            if you want more advance, just use weaker springs/heavier weights...
