So I read you can swap late model w cars heads and intake onto a 3.4 camaro. I know it creates a compression of around 13:1 but thats no worry as im getting pistons and a cam that should blow some pressure off. Is this true though? and is it the LA1 engine that is swappable or LQ1?
Interchangeable heads and intake on 3.4 camaro
it's the LA1.. but if you want the best stuff then get a 3500 top end (LX9). It'll drop your compression down far enough that you wouldn't have to change pistons.. 11.5:1 or so.
If it's a 4th gen Camaro, i seem to remember an issue with hood clearance or cowl clearance to the 3500 UIM.. but people have done the 3400 stuff. Forced_Firebird is the resident Fbody expert.. maybe he'll chime in.Originally posted by b-mo View Posthow much modding would be needed?
Maybe :POriginally posted by Superdave View PostIf it's a 4th gen Camaro, i seem to remember an issue with hood clearance or cowl clearance to the 3500 UIM.. but people have done the 3400 stuff. Forced_Firebird is the resident Fbody expert.. maybe he'll chime in.
Cowl clearance for sure on a 3500 UIM. 3400/3100 UIM needs the numbers shaved off to clear.
My fav is 3.4/3500 with tuning. 11.5 or so to one CR, and rape some LT1's.
Got a manual or auto?
Originally posted by b-mo View Postit would actually compete with lt1's? I have a manual so im guessing i gotta strengthen the gearbox if I put out more than 300 ft/lbs. What kinda numbers would I be looking at?
Doubt it will be over 300ft/lbs. Yeah it will keep up with a bolt on LT1.
Since you have a manual, you should swap in a '7727 ECM and start with tuning. Once you have that down, do the top end swap.
If you get an ECM out of a V6 car, then the correct knock sensor filter will be in the MEMCAL
Lumina 3100 cars is what i pull them out of. Check out car-part.com to get what you need...
EDIT: I am in the process of making some wiring harness adapters so people can just plug and play on the ECM's if you are interested. Haven't come up with a price for the adapter alone, but I am offering the ECM, harness adapter, ECM, chip, chip adapter, and USB datalog cable for $500. There is currently a couple people on the waiting list. I'll come up with a price for the adapter alone as soon as I finish the prototype - just in case you want to buy the rest on your own, but I'm not making any money on the rest of the parts. Even comes with a useable tune for the 3.4's
