3*00 timing gear drives?
  • gar70614
    • Oct 2008
    • 330
    ii there a timing gear drive avalible for the 60* motors. i know expecially 2000+ are vulnerable to chain stretch and there are a double and hopefully soon a single roller set avalible but any gear drives?
    THIS ONES FOR A SBC BUT SAME IDEA.
    Free Shipping - Summit Racing™ Gear Drives with qualifying orders of $109. Shop Timing Gear Drive Sets at Summit Racing.
  • TiredGXP
    • Jun 2008
    • 107
    Even if they had them, you don't want to use a gear drive with a vehicle equipped with a knock sensor - the damn things are so noisy, the knock sensor will constantly be detecting "knock". ECM will pull all timing.
      No, there is not.. nor will there be. Just use the '99-older timing set or one of the double rollers from TCE.
      The distance between the crank and cam is one issue on the 60 degree engines, The other is the previously mentioned noise problem with the knock sensors.
      • gar70614
        • Oct 2008
        • 330
        so a 99- will is a solution i was under the impression they were beter but not by much. all the threads about gve me the impression the chains were a weak link. thanx tho guys just wondered i know a few guys with 700hp+ sbc's that were running them a figured i would ask.
          99 and older 3x00 chains are beefier but not bullet proof. A big cam /stronger springs will still wear it out.
          • 60dgrzbelow0
            "Yes... I AM IRONMAN..."
            • Mar 2009
            • 1344
            The front casting walls of the 60* engine in the area where the "spider" transfer gears would be are not thick and strong enough to handle the kind of flexing and stress the Timing Gear Drive System would bring...
