2.8 intake/carb help WANTED
  • Mike Lieb
    • Aug 2009
    • 1
    I`m new hear and don`t know my way around to good yet so forgive me if I`m redundant.
    I have a 2.8 from a 85 S-10.I thought That it had a Throttle body but I found out today its a carb.
    In a nut shell I just want to change the intake and carb. to something more "normal" I don`t know anything about this setup and I want to strip the motor down as much as I can to make it fit into a midget.
    I know edelbrock makes two intakes that would work.
    Better still would be to find something used that would interchange.
    I have the old "carb"but I think I need the computer and fuel pump to make that work dont I?
    Thanks for any help.
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    you can switch to an earlier non electronic carb and distributor that will be tunable with a screwdriver just like any other carb.
    What you have is the Rochester E2SE carb which has an electronic mixture control. Most vehicles before 85 has the 2SE carb which is a standard carb. They also had a mechanical/vacuum advance distributor. The 2SE carb is just like a Rochester Quadrajet sectioned in half down the middle of the carb.
    There are also Weber carb kits and Edelbrock and Holley 2bbl carbs that will work.
