help me get ideas for a 3500 build
  • 01GPGT
    Curse you Red Baron!!!
    • Jun 2008
    • 214
    just want ideas for a 3500 build.
    i figure ported top end and mill the heads
    what kind of CR could i get with the stock pistons? (i am not sure what kind of head gaskets are available)
    any one have an idea of a cam? plan on having a good N/A engine fist then boost later but not sure.
    any other ideas would be nice
    92 LeBaron Convert: Does it run yet? 03 Silverado 2500HD ecsb 4x4 6.0L: dual 3" in/out race "muffler" 2005 Ford Taurus SE 3.0: DD from california
  • mfuller
    Mr. Common Sense
    • Nov 2003
    • 374
    Milling the heads may only get you a few tenths of CR, so figure 10:1 or therabouts (factory SCR is 9.8:1).
    Use the cam selection service through the store to find out the best lobe profiles for your particular application.
    Matt
    • 01GPGT
      • Jun 2008
      • 214
      CR of 10 is it for the stock pistons? hmm to bad custom ones are so expensive i wouls like to get a CR of 11 out of it (hey the 3.4/3500 hibrids are getting higher and are fine)
      oh well maybe i will get alot of money out of now where lol
        those 3.4/3500 builds aren't planning on running boost though.
        there are two schools of thought on boost
        low compression + lots of boost
        high compression with less boost to make the same power
        now, i'm more fond of using stock compression and adding boost for a few reasons, number 1 being you won't lose much fuel economy and power out of boost due to the lower static compression ratio.
        if you're going to try and run 11:1 with boost, its going to need to be limited to maybe 4-5psi, run premium gas like its going out of style, switch to colder plugs, and a LOT of tuning to get the spark table to where it won't knock...
        • 01GPGT
          • Jun 2008
          • 214
          boost would not be for a long time (at least 4 years) heck it might never see boost
          but ya i do not mind using premium every car i have ever bought has need it except the van but thats my parents car
            this should give you some ideas...
            A forum community dedicated to J-body owners and enthusiasts. Come join the discussion about performance, engine swaps, modifications, classifieds, troubleshooting, maintenance, and more!
            Pretty much any cam you put in a 3500 will make it a screamer.
            • 01GPGT
              • Jun 2008
              • 214
              thanks. it also seems i am right on using a TPI fuel pump as well. (some G-body guys where not sure if it would be enough)
              i have noticed the stock cam is a little anemic in the power area
              • Driver_10
                • Jul 2006
                • 487
                When you say "build", what kind of budget are you throwing at it?
                • mfuller
                  Mr. Common Sense
                  • Nov 2003
                  • 374
                  Although I think Dave's custom long-tube headers also go a long way towards helping his big output.
                  Matt
                  • 01GPGT
                    • Jun 2008
                    • 214
                    undecided as of yet depends on the condition of the car when i get it back (currently trying to get back my old 82 GP that was stolen that i recently found it was hiding in canada)
                    if the car needs alot of work the engine will remain stock (215 HP is more then any factory engine) or i may not put it in at all really depends.
                    but say in a perfect world for the N/A build (always planned on using the stock bottem end for the N/A set up) i say enough to get a ported UIM/LIM heads and a cam. i have no idea what to do for headers. if the 3.4L camaro headers will fit Gen III heads i will use thoughs if not i will probably make some even though i realy do not feal like doing that
                    • 01GPGT
                      • Jun 2008
                      • 214
                      his headers are a nice. i think even on a stock engine you would see some nice gains
                        the stock logs are horrible, so of course, but true long-tube headers are about as good as it gets, unless you're gonna run zoomies
                          lol.. thanks
                          Take a look at Redbird's 3500 swap. Stock bottom end with a .506 lift/270 advertised 111 LSA cam, P&P'd top end and 3500 "header" manifolds with a decent tune. He's making almost 300 @ the crank and an easy 260 WHP.
                          The car is daily drivable and runs mid 13's
                          • 01GPGT
                            • Jun 2008
                            • 214
                            i have a bunch of G-body guys intersted in this now
                            all i asked was what tank and pump to use then they wanted to know what engine and it all went from there posted links to this forum
                              i like the idea of a TT 3900/T56 powered 86-88 Monte SS....
