3100 compression
  • 95Grand-Am
    • 268
    3100 compression
    What should a good fresh 3100 have for cranking compression? Does GM have any specs for it?
    normal would be around 150psi
    the recommended minimum is 100psi, with no more than 30(?)% difference between the highest and lowest cylinder.
    • 95Grand-Am
      • 268
      Could a stock 3100 have 200psi?
        depending on how well the rings and valves are sealing and how much carbon has built up inside the chamber, yes.
        • Azrael
          Accelerating uphill in OD
          • Apr 2005
          • 763
          With 190,000km, mine was between 170 to 185 psi. Warmish and no oil added.
          1995 Grand Am SE
