Got a few questions about my monte.
  • mike0589
    I Love My 60*
    • Feb 2007
    • 30
    Hey everyone i have a few questions, I just got a set of fuel injectors from the j/y, They are off a 95 Z34 with an LQ1. I know i have to tune for them but they should work right? I was also thinking of getting a catback off of a Z34, But i am not 100% sure if it will bolt right up or not. Also can anyone tell me what my options are as far as a downpipe? I know i can get one from ZZP but if i am able to get one off of some car at the j/y and have it bolt right up that would be awsome.
    Thanks in advance.
    1998 Monte Carlo LS, Dark Carmine Red Metallic.
    P&P 3400 UIM, LIM, And TB.
    Custom FWI / Descreened MAF.
    Polyurethane Dogbone Engine Mounts.
    MMS PCM, Dyno Tuned.
    180*T-Stat.
    Custom Shift Kit.
    Taylor ThunderVolt 8.2mm Spark Plug Wires.
    LQ1/LHO Oil Filter.
    GMPP Front And Rear STB's.
    SS Rear Brake Lines.
    your injectors now should be 19lb/hr, while the 3.4 should have 21lb/hr(?), while slightly larger and a tune would be advised, they will work.
    i would be wary of stuff from MMS. ask someone here who has bought stuff from milzy and then go from there.
    • mike0589
      I Love My 60*
      • Feb 2007
      • 30
      Bump. Thanks. So does anyone have a definite awnser on the lb/hr on 3100 and 95 LQ1 injectors?
      180*T-Stat.
      Custom Shift Kit.
      LQ1/LHO Oil Filter.
      • mickaz
        • Aug 2004
        • 350
        19lb/hr iread your question wrong forget that
        Mike 60degree addict.
          no, you're right, the 3100 uses 19lb/hr...
          • mike0589
            I Love My 60*
            • Feb 2007
            • 30
            Ok cool, Now if i can just find out if the DOHC injectors are for sure 21lb/hr i should be good to go. If anyone has any other info that may be useful feel free to chime in.
            180*T-Stat.
            Custom Shift Kit.
            LQ1/LHO Oil Filter.
              • mike0589
                I Love My 60*
                • Feb 2007
                • 30
                Awsome, Thanks for the link.
                180*T-Stat.
                Custom Shift Kit.
                LQ1/LHO Oil Filter.
                • mike0589
                  I Love My 60*
                  • Feb 2007
                  • 30
                  I got some more questions for you guys. I am thinking about buying a downpipe from ZZP for the monte, They say it is for the 3400 impala, But i see no reason why it should not work with the monte. What do you guys think?
                  Also can anyone tell me if 3400 or 3500 exhaust manifolds will bolt up to a 3100, And if so are the ports bigger?
                  180*T-Stat.
                  Custom Shift Kit.
                  LQ1/LHO Oil Filter.
                  • mike0589
                    I Love My 60*
                    • Feb 2007
                    • 30
                    Bump. Got a new question, And it's kind of a noob one. A buddy of mine has a set of autolite 104's with less then 1K on them, He got new plugs and said i could have his. I'm about due for new plugs anyways. My question is, Would that heat range be good for a N/A car with my mods? If someone could school me on heat ranges with N/A cars it would be much appreciated
                    Thanks.
                    180*T-Stat.
                    Custom Shift Kit.
                    LQ1/LHO Oil Filter.
