I took my 3400 powered Fiero to the dyno yesterday. The results were better then I had expected. The car put down 177.5 hp @ 5020 rpm and 206.7 ft. lbs. @ 4125 rpm @ the wheels. This is a completely stock '02 3400 running on a '95 Firebird OBD 1.5 ECM. We are at a pretty high altitude here. The dyno program also has a feature to correct the numbers to a more "standard" altitude and humitity level. When this is aplied it is 204.5 hp/238.1 ft.lbs.@ the wheels. The only things I have done to the engine is free-flowing exhaust and intake. The best run was when the car was cooler. I lost a couple points as the car got hotter. You can read about the car on my build thread here http://www.fiero.nl/forum/Forum1/HTML/071783.html dyno result is on page 5. I would like to try to do some improvements in cooling to keep the engine in it's most powerful temp. range. Any ideas? Also I was wondering if going to a larger TB and 3500 upper plenum would be worth it since I can't tune my engine? Would I still see gains?
3400 dyno results
Tags: None
The common thought is that the 3400 UIM actually flows better than the 3500 in stock form.
I have yet to actually try it (I'm going to) and as far as TB size goes, 56 - 62 mm seems to be what runs best on a basically stock set-up.
Those are pretty damn good numbers for a 3400 on OBD 1.5!!
205/240 at the wheels (corrected) is bad-ass for a stock 3400...
i think the 1.5 3100 PCMs would have a better fuel/spark map than the 3.4....
as far as tuning, if its a 5 speed, you can swap to a 7727/7730 and ben has a chip set up in WOT-Tech for it...
3500 plenum has smaller ports than the 3400 gasket stock. Open them up to match and boom you have outflowed the 3400 plenum, PLUS you have more plenum space/etc/etc. It broadens the powerband is the main benefit. Plus it's already at 65mm for a TB.
You need to swap to an OBD1 ECM that you can tune. Won't be that hard. Then you can tune and get the full potential out of it.sigpic
that's pretty good, 5 speed 3400 swapped Jbodies are putting down around 190-195 at just under 1000' above sea level.
I am waiting for Forcedfirebird to finnish his OBD 1.5 swap "kit" Although his thread on it seams to have kinda gone dead lately. If I use his peices the re-wiring would be kept to a minimum. With this I could run Ben's chip for the 3400.
Well that puts me right in line with them I think. The elevation here is 2986 ft. and the humidity on the day of the run was a little over 30%.Originally posted by Superdave View Postthat's pretty good, 5 speed 3400 swapped Jbodies are putting down around 190-195 at just under 1000' above sea level.
You show a 7730 PCM in the thread, but I take it it's not wired in yet...
Did you see Robert's thread on OBD1 swap? The guide has pin-outs that you could apply from the OBD1.5 PCM to the 9396 or even 7730. IIRC the 9396 PCM can even take bins that the 7727/7730 take (sites list the 7727/9396 as interchangeable. Difference is 9396 has more memory for controling trans in the bin). But that doesn't matter as you have the 7730. I'd just keep the SFI OBD1.5 harness you have on there and re-pin on the 7730 using Robert's guide as guidance. Boom you're done. Who cares if extra wires go to sensors no longer being used? Unless you'd want to clean up the engine bay by keeping wires to a bare minimum (IE removing 24x crank, cam, etc sensors)sigpic
john isn't the only one or the first to have accomplished it...Originally posted by Bridgetown View PostI am waiting for Forcedfirebird to finnish his OBD 1.5 swap "kit" Although his thread on it seams to have kinda gone dead lately. If I use his peices the re-wiring would be kept to a minimum. With this I could run Ben's chip for the 3400.
i did it to my monte as a "proof of concept", then he got it done to one of his customer's cars shortly after IIRC.
EDIT: isaac: the 7727 and 16149396 are directly interchangeable. at least going from a 7727 to a 9396 is. can't run a -E tranny on a 7727, but, yes you can run any codemask that a 7727 can on a 9396. 7730 has the 3 connectors that are WAY different from the other two...Last edited by robertisaar; 09-15-2009, 01:45 PM.
'7730 > all
My OBD1.5 bastard computer is inside the car, but weather proof. I like the housing on it, cast aluminum looks rugged and should have good heatsinking. I think the older weatherproof ECM's had steel case though.sigpic
I do believe you are right, the case does look like steel (painted black). I've got 3 '9396, soon to have have 2 since joelbob is interested in one and the under hood harness on the 91 for his project.
Edit: BTW, nice numbers
Got anymore? How much for a 9396 and pigtials?
PM me if you got one for sale.
meh, if i can get water up under my dash i probably deserve my ECM to cook.Originally posted by robertisaar View Posti like weatherproofing
9396 for me
