Equinox upper intake?
  • geldartb
    The Situation
    • May 2004
    • 1994
    Mars, yeah but you'll have to have a hole in your hood for this thing! lol
    stop giving me reasons to cut a hole in my hood.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    • Mars
      • Apr 2004
      • 826
      Was thinking of something along the lines of a turbo hump like some DSM's and the older Dodge Shadows.
      I think I'd have to re-port the whole neck in one to get my 70mm TB on there and I don't have much ambition to do such a thing.
        Actually that was to clear the timing belt pulleys on the 4g63 engine.
          • 9191
          This TB neck stands about 4" above the top of the plenum, so I doubt it would be just a bump. I know a small port 3100 with 1" spacers causes the plenum to hit the hood on a Beretta, so figure it will be about the same with a 3500 style and any other car platform. So look at ~3" protruding from the hood...
          • geldartb
            The Situation
            • May 2004
            • 1994
            Brad i got 1" spacers and a large port 3x00 UIM on the 5th gen grand am and it doesnt hit the hood.
            the only thing that touches the hood is the wiring harness. Nick G probably could get away with maybe 2 or 3inches at the most.
            99 Grand Am GT
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              #21
              Yep, and for the turbo mopars, it was used to clear the intake/recirc/charge pipe.
                I was referring to the DSM cars, not the Mopars.
                • Nightingale
                  • Apr 2005
                  • 259
                  #23
                  does the equinox 3400 upper share the same port shape and bolt pattern as the 3.5L vvt and 3.9L vvt? Just realized the headaches it would save in term of power steering location for those motors if this manifold would bolt up. Then of course you have the hood issue(nothing a cowl couldn't take care of in rwd platform )
                  98 camaro swapping in lz9 th400 setup
                  LZ9 specs: (Subject to Change work in progress)
                  4.0L(after bore 3.917 and stroke 3.3485),carrillo sbc rods(narrowed),wiseco custom forged pistons 8.5:1 CR, TCE Double Roller timing chain, gen 3 cam, P&P heads, headers 1 3/4 primaries into 3-1 collector, and going to run ms2.
                    #24
                    No it shares the same as the 3400 and LX9 3500.
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      #25
                      I know that. I was giving more detailed info on the mopar "hump" .
                      • 01GPGT
                        Curse you Red Baron!!!
                        • Jun 2008
                        • 214
                        #26
                        should clear a G or 3rd gen F-body just buy a cowl hood
                        92 LeBaron Convert: Does it run yet? 03 Silverado 2500HD ecsb 4x4 6.0L: dual 3" in/out race "muffler" 2005 Ford Taurus SE 3.0: DD from california
                        • latemodelnewbee
                          • Jun 2007
                          • 227
                          #27
                          I may need to get one or at least take a look at one. it will make my creepy project a little easier an AE86 corolla with a 3400 (the tuners kids won't know what hit'em)
                          68 El camino 454 speed muncie 3.90 posi 12 bolt,
                          80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
                          60 Impala 2 door hardtop L79-327 T56 4.11 posi.
                          83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
                          91 Z34 now has a hm284. and belly pan in the works
