bad idea?
  • no_doz
    • Sep 2005
    • 912
    werent the 94 ecms obd1.5 for the most part?
    • dusterbd13
      • Oct 2008
      • 102
      talk to me some more about this external crank trigger setup. pics, links, how-tos, etc would be appreciated. depending on cost, this may be the del breaker for me.
      michael
        Pure bolt on so that your ECM has the right reference to go by for the ignition and fueling events. Too bad it is out of stock right now.
          about the only 1.5 ECMs in 94-95 were the 3100, 3.4iron head, LT1 and i think a 4-cylinder or two... those were the only flash ones IIRC...
          so a 94 3.1 is fine, it should actually be a 16149396....
          • no_doz
            • Sep 2005
            • 912
            didnt the 94 cavalier Z24 have OBD1.5 then?
              they got the 3.1, not the 3100...
              • RedBird
                Aka Mr. 5th Motor
                • Sep 2006
                • 426
                #22
                no, 94 J-bodies got OBD1. GM didn't feel like going through all the trouble to put OBD1.5 or the 3100 in the 94's, since the V6 was going away in 95 anyway.
                Cammed 3400 --> 224whp 210wtq
                Cammed 3500 --> ???
                1 of 5 3500 J-Bodies
                • no_doz
                  • Sep 2005
                  • 912
                  #23
                  fantastic info-so i suppose this means i wont be going out & looking for a sunbird 5 speed with a 3100 in it & OBD-I then.
                  thanks for the clarification guys-also robert is there some sort of chart that shows what computers went in the different gm fwd's?
                    chart? no, but it would be simple enough to make one. what all do you want to know? ALL FWDs? just 3.1? just 3100?
                    BTW: you wouldn't find a 5 speed 3100 ANYTHING from the factory. never happened (unfortunately). but swapping a 3100 in place of a 3.1 is easier than swapping a 5 speed in place of a 4t60e.
                    EDIT: that would actually be a 4t60, apparently only the W's got a -e in 93/94 in 3.1 apps, the others should only be a 3.1/4t60 or 3.1/th125c.
                      • 9190
                      #25
                      No 3x00 was ever bolted to a 4T60 either, it was always a 4T60E.
                      • no_doz
                        • Sep 2005
                        • 912
                        #26
                        very good info-sad to hear that but are you sure none of the pontiacs came with a 5 speed?
                          positive. there might have been 3.1(LH0) 5 speeds in 94, but thats as close as it gets.
                            That would have to be one simple as pie swap. I didn't have any problem at all swapping a 284 into the 91 to replace its 3rd blown 4T60-E.
                            • dusterbd13
                              • Oct 2008
                              • 102
                              #29
                              so, back to the origonal not so bad idea of the day.
                              my shopping list would be
                              1. pair of 3100 or 3400 heads
                              2. intake from same motor, as well as the injectors, throttle body, coils, wires, etc
                              3. set of pushrods from???
                              4. the crank sensor conversion from wot-tech
                              5. eiring and pcm from???
                              6. dremel tool to slot some holes
                              7. gaskets
                              am i missing anything? what gaskets would i use? is there a thicker head gasket that could knock some compression down?
                              could someone double check my compression math? depending on which 2.8 i select, i get on the 12;s, or low 13's.
                              thanks for the helps os far guys. if were sure this will work, ill add the part list to my junkyard bag. that way when i spot something that will work, i can snag it. especially on half price day.
                              michael
                                With the 3x00 top end, be SURE you get the metal intake gaskets, not the plastic ones. The extra price is well worth the headache they will save you...
