What is BEST Sark Plugs for 3400 V6
  • Bens71442
    • Dec 2004
    • 17
    What are the absolute BEST Plugs Money can buy, for a 2002 Alero with a 3400 V6?
    Installed 2500 miles ago Auto lite Double Platinum APP606
    Now experinceing Cold idle rough run.
    Rough IDLE completely disappears after 3 to 4 minutes run time
    HOT restart no issues what so ever.
    Help me please before I drive me and my Alero into Lake St.Clair
    Platinum plugs don't work in these engines. Never have and never will.
    the AC-Delco Iridiums are the best you can get.
    • AaronGTR
      boost lover
      • Jan 2004
      • 708
      Well, that really depends on what you have done to the car. There is no one best plug. There is only a best plug for a specific application based on needs of how the engine runs. Is your engine mostly stock? Then I'd say you probably should stick with the stock AC delco platinums or the new iridiums that came in the latest 3400's. They should be stock heat range also. Autolite plugs don't have the best reputation so they may be your problem right there.
      '97 Grand Prix GT 3800 (sold)
      Gotta love boost!
      • asylummotorsports
        Banned
        • Oct 2005
        • 649
        What Superdave said! PERIOD!
        • Bens71442
          • Dec 2004
          • 17
          Wow!
          I would have never known that Platinum plugs aren't worth a hill of beans on the 3400 V6
          They are coming OUT tomorrow morning as soon as I'm finished with my daily morning internet porn. Just kidding.
          I guess I'll go back to the AC Delco Iridiums but I can't stand the price of them.
          After I put these Double Platinum Auto lites in there my power gain was very noticeable.
          I have done NO modification to this stock 3400 V6 and its not my intention to do so.... just my daily grocery getter vehicle here.
          IS there a big enough difference with the Heat range with the plugs I installed?
          Auto lite Double platinums APP 606
          Is or Are the 3400 V6 engine this susceptable to improper heat range of a spark plug?
          Are Auto lite Double platniums that far off to be casing this rough idle cold engine condition?
          I'm shocked if these plugs are the cause of this rough run cold. but evidently, all the signs point to the plugs
          after they warm up after 3 to 4 minutes run time; idle smooths out perfectly and NO rough run at all.
          No rough run after hot soak and restart. No rough run on a warm engine either!!!!!
          • AaronGTR
            boost lover
            • Jan 2004
            • 708
            Well, I don't really agree with that. It's just certain platinum plugs from certain manufacturers in my opinion. I never had problems with the stock platinum plugs in mine and never have thousands of other people with factory plugs in 3400's. They last for 100k miles which is what platinum is for. It's just that iridium is a little better because the smaller tip requires less voltage for the spark to jump.
            And yes, any engine can have problems with plugs of the wrong heat range. They are more likely to foul and cause bad idle if they are too cold. For a stock engine, you need plugs in the stock heat range.
            Gotta love boost!
              the stock Delco Platinums are better than the Autolites and Bosch plugs, but not by much. Bosch and Autolites are junk, lol.
              our waste spark DIS system kills platinum plugs. Iridiums are well worth the money, one set will last longer than your engine.
              • andrew383
                • Nov 2007
                • 70
                can you give more detail as to why (copper core) autolites are junk?The 97-current W-body guys swear by them.
                The stock plug is a 606 rite?Whats the delco part #,and whats the next range colder plug?
                sigpic03' 3100 slp cat back-custom fwi-gmpp trailing arms-mrz udp-aeroforce
                  i don't know which w-body forum you're on but on w-body.com, we know that anything other than the ACDelcos are pointless...
                  • gectek
                    Banned
                    • Aug 2006
                    • 1472
                    ngk makes ACdelco irridium and some others
                    I like the NGK TR55
                      http://60degreev6.com/forum/f86/spar...-motors-t37003
                      Read...
                      Stock plug as long as it's in good shape will give you most power. You won't gain any power by a different plug, only loose power if they are worn out or the wrong plug.
                      If you don't want to pay for iridium then get the plain AC delcos at the top of the list on that link for gen3 I posted. that's what I run and they hardly wear much at all.
                      • mfewtrail
                        ~600hp worth of 3.1's
                        • 170
                        I've used a lot of copper core autolite plugs and never had a problem with any of them. I bought several sets of 103's on closeout locally(for something like $1 for a pack of two) and I'm currently running them in both of my TGP's. I can tell absolutely no difference between them and the AC Delco R42LTS'.
                        For what it's worth, I recently talked to a rep at NGK and they told me that NGK, Denso, and possibly Honeywell(autolite) supply GM with spark plugs for the AC Delco brand.
                        Matt F.
                        TGP 1/4 mile times
                        http://photobucket.com/albums/y33/mfewtrail/
                        1990 TGP Coupe VIN Database
                        • 1988GTU
                          LB62LHObbqftmfw
                          • Nov 2005
                          • 2475
                          THE BEST spark plug is one that sparks! Duhhhhhh!
                          • PCGUY112887
                            • Feb 2006
                            • 1067
                            I believe it's the 97+ w-body L67 GTP guys that swear by the copper autolites. For them it may be that way because different plugs react differently to boost vs the N/A 3400.
                            SpudFiles
                            Theopia
                            Enjoy life online.
                              I haven't used the copper core, just the regular platinums. i put a set in my old GAGT and they started acting up after about a month. I replaced them with 50K used iridiums from my spare 3500 and put another 20K on the car with no problems.
