94 Firebird 3.4L OBD1 swap
  • Firehawk94
    Fbody Fiend
    • May 2009
    • 179
    Ok will do. About the valvebody swap, that sounds like a good route to go and I have experience with valvebodies which means it would be an easy feat for me to accomplish, but I wouldnt want to dive into this without more information.
    94 Firebird 3.4 DD
    252000mi. All original
      Hmm amperage eh? PWM can control amperage, but so can other ways... Someone with electronics knowledge could whip up something that reads a 2nd MAP and varies the current based on load... You could even put a potentiometer on there to chang the bias incase you wanted more firmer or softer pressures per load.. Wouldn't be that hard to do I would think... Unless the MAP is not really linear... But that could be overcome as well but would require a bit more knowledge of electronics. Maybe a PIC IC would be good here...
        MAP is very linear.
        (.369*N)+10.354 = kPa
        that's the equation i use in all of my ADS, XDF and ADX.
        essentially, except for the 10.354 offset, it's perfectly linear.
        i had a chart somewhere that gave voltages vs kPa readings... oh well, takes two minutes to make.
        EDIT: for this situation, this should work:
        kPa____Voltage___A/D Counts
        15______.25__________13
        20______.51__________26
        25______.78__________40
        30______1.04_________53
        35______1.31_________67
        40______1.57_________80
        45______1.84_________94
        50______2.10_________107
        55______2.37_________121
        60______2.65_________135
        65______2.90_________148
        70______3.18_________162
        75______3.43_________175
        80______3.70_________189
        85______3.96_________202
        90______4.23_________216
        95______4.49_________229
        100_____4.76_________243
          Hmm. I bet you could make a quick and dirty circuit with a voltage regulator running in current regulation mode, controlled by a 2nd MAP that was running off 5v (possibly from another voltage reg). If we knew how much current the force motor needs, that could be devised....
            the highest you can read according to the datastream is 5 amps...
            56 CURRENT FORCE MOTOR COMMAND CURRENT
            AMPS = N/51
            57 CURRACT FORCE MOTOR ACTUAL CURRENT
            AMPS = N/51
