2.8 Stroker kits!!!!!
  • partsandpieces
    • Oct 2009
    • 7
    Check out removed for the best stroker kits, and high performance cam shafts.
    • 9191
    Yeah, not gonna let ARI get free advertising on here...
      lmao
      • neo71665
        its this big
        • Oct 2005
        • 361
        Fail at relabeling factory parts and fail at spam
        87 3.4 4x4 blazer
        • sil
          4T60-E killa
          • Nov 2004
          • 723
          you removed the link from the message body, but it still remains in the "tag" :P
          • 60dgrzbelow0
            "Yes... I AM IRONMAN..."
            • Mar 2009
            • 1344
            Yeah, not gonna let get free advertising on here...
            • partsandpieces
              • Oct 2009
              • 7
              I was just posting it as reference, they have supplied good parts for me. By the way will a 3800 throttle body bolt up on a 3100?
              • AaronGTR
                boost lover
                • Jan 2004
                • 708
                No, and why would you want to use a 3800 TB? Even if the bolt holes lined up which the don't, it uses a rubber O-ring to seal to the factory plastic upper intake on the 3800 and the IAC is in a different spot, so that wouldn't work. Plus it's longer and has a venturi style MAF built into it.
                iirc the early 3100's came with a 52mm TB? Not sure if the later 3100's with the large port intake mani's from the 3400 came with the larger TB or not, but the 3400 came with a 56mm TB so you could probably use that if you were looking for a cheap oem upgrade. Otherwise you can get 62mm or 65mm from WOT tech.
                '97 Grand Prix GT 3800 (sold)
                Gotta love boost!
                • partsandpieces
                  • Oct 2009
                  • 7
                  Thanks for the information.
                  Yeah I will use a 3.4 , like wise the the whole intake. Since it has better, flow.
                  • neo71665
                    its this big
                    • Oct 2005
                    • 361
                    They just supplied you with factory GM parts at a high price and you bought it thinking it was a real stroker kit. GM done the "stroker" when they went from a 2.8 to a 3.1 so the parts were already out there and normally a lot cheaper than the fake stroker kit.
                    87 3.4 4x4 blazer
                    • geoffinbc
                      Iron Head Enthusiast
                      • 5831
                      I have a stroker crank in my garage. Anyone want to buy it?
                      • neo71665
                        its this big
                        • Oct 2005
                        • 361
                        I have about 3 3.4 de-stroked cranks up for sale
                        87 3.4 4x4 blazer
                        • torq455
                          If I only had money!!!
                          • 1615
                          haha, for real!
                          Andy
                          fastest 1/8: 10.19@ 67.17
                          fastest 1/4: 16.16@ 82.70
