Converting from VaraJet E2SE to 2SE ???
  • pgtr
    • Jun 2008
    • 27
    I have a very original '84 FBody with 2.8L V6 (200k mi) and E2SE carb w/ computer controlled ignition etc.
    I'm tired of dealing with the aging and convoluted end-of-carb-era emissions controls and am contemplating switching it out. Engine runs fantastic except for intermittent carb issues that I'm tired of dealing with.
    I would change out the E2SE for a 2SE (early 80s S10) carb eliminating the mixture control solenoid, TPS etc.
    I would also change out the distributor for a conventional vac advance distributor from an early 80s S10.
    A few questions:
    Q: Would the gas mileage be similar or comparable to my '84's current mileage (25 hwy)?
    Q: Does the earlier 2SE carb still use the EFE pre-heat grid in the carb base gasket?
    Qoes the ECM become a boat anchor or do I need to it's (removed) sensors?
    Q: I think the EGR valve is computer conrolled - how would I hook that up (or should it be bypassed)?
    Q: Will tbe cruise control still work OK?
    ...any other comments, inputs or suggestions regarding this contemplated project?
    thanks
    not sure to a few of those answers, but should you need a wiring diagram, i've got them for you.
    • pgtr
      • Jun 2008
      • 27
      Q: Also can a Hi Perf HEI distributor for a modern 4.3L V6 work in my older 2.8L OK?
      thanks
