Megasquirt on a TBI 2.8???
  • 2.8-350TBI
    RWD FTW!!!
    • Sep 2009
    • 350
    Hello to all, and happy thanxgiving!!!
    I own a '89 blazer w/ the 2.8 TBI, has a 5.7L throttle body already.
    I want to ask if Megasquirt II can run TBI, because im planning on buying it, and wanted to hear the '60 community's feedback.
    I will be upgrading to 3400 heads in the future, and wanted to know if it is expandable to convert my engine to DIS and MPFI once I get the head swap going. I ask mainly because of this, but would like to run MS on the ol' TBI before losin iron...
    Originally posted by Mars
    Haha ^ Wrong Wheel Drive.
    No 60šV6 at the moment
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Yup it can run it all you would have to check is that the injector driver can handle the low resistance injecors
    • 2.8-350TBI
      RWD FTW!!!
      • Sep 2009
      • 350
      It sure can; up to 4 hi-imp, or 1 lo-imp per cylinder...
      Taken that it works w/ TBI, will I be able to convert it to MPFI once I get the 3400 top end?
      • Barry
        95 Beretta LG8 Action
        • Aug 2007
        • 269
        Yes indeed!
        The beauty of MS, it can do pretty much anything.
        95 Beretta- Lg8 Daily Driver
        • 2.8-350TBI
          RWD FTW!!!
          • Sep 2009
          • 350
          ALRIGHT!!!! WHOOP WHOOP!
          Ill buy it within a couple of days, and ill more than likely be back in search of MS-guidance
          • MidnightriderZ24
            • Jan 2005
            • 699
            trust me on this, have patience assembling! lol. u can mod it to run gm dis no problem, with a few resistors and jumper wires. easy mod. i cant wait to get mine running on it!
            [SIGPIC]
            12.268@117... 11's to come!
            • 2.8-350TBI
              RWD FTW!!!
              • Sep 2009
              • 350
              Hahaha, im just daydreaming, but even an itb setup using three tbi units could be mocked up on a custom UIM on the 3400 top end using DIS, how fun would tuning that be? LOL
              Introducing; THE TRIPLE CROSSFIRE!
              ...ŋJetfire maybe?
              • Azrael
                Accelerating uphill in OD
                • Apr 2005
                • 763
                I can't wait to get mine running too. Sooo very close though. Have to rewire my grounds due to ground offsets messing with my wideband lol.
                1995 Grand Am SE
                • Raffaelli
                  DeBadged
                  • Sep 2009
                  • 30
                  Am I just an Idiot or can MS2 only run 4 injector drivers?
                  If so, no sequential FI? Correct?
                  • 2.8-350TBI
                    RWD FTW!!!
                    • Sep 2009
                    • 350
                    I like hearing all these positive things for megasquirt
                    Good luck on your megasquirt builds guys, and if you get bored enough, you could maybe do a write up for megasquirt setup/tuning, as I have found nothing!
                    I suppose megasquirt supports coil on plug (COP) ignition coils also???
                    If so, I would really like to be going this route.
                    • 2.8-350TBI
                      RWD FTW!!!
                      • Sep 2009
                      • 350
                      I didnt find anything on 4 injector drivers BUT, it runs sequental injection drivers!
                      And youre not an idiot. Google is a click and six keys away...
                      Last edited by 2.8-350TBI; 12-01-2009, 10:56 PM. Reason: Raffaelli is not an idiot :)
                      • 2.8-350TBI
                        RWD FTW!!!
                        • Sep 2009
                        • 350
                        Hey, I just answered my own question, it CAN run COP!
                        • Azrael
                          • Apr 2005
                          • 763
                          Megasquirt has 2 injector drivers (you can run a dozen high impedence injectors on each) for alternating bank or simultaneous injections (MPFI). SFI won't be available until Megasquirt 3.
                          1995 Grand Am SE
                          • MidnightriderZ24
                            • Jan 2005
                            • 699
                            as stated u can run up to 12 high ohm injectors on each driver. as for coil NEAR plug, theres a few mods to do, and YES you can run sfi!!! theres a daughter board theres actually a kit on diyautotune. you need to modify like i said and use ms extra, but if you plan on running ignition with MS then you will have the coded loaded already.
                            [SIGPIC]
                            • 2.8-350TBI
                              RWD FTW!!!
                              • Sep 2009
                              • 350
                              That sounds great. I was reading up on the sfi daughter board yesterday, and I figured I should try to get something like that going.
                              Wouldnt that be sweet
                              Forgive my newbness, but ive searched near and far for the difference between MPFI and SFI and have not found any clear answers.
