Aluminum Block found
  • NFSINSANE
    • Aug 2009
    • 32
    I was looking at pushrod performance articles under the mototr articles section and saw a section on an aluminum 60 V6 block block. I was very interested just because thats sick. It also said they were dicontinued and hard to find. I'm sure many may already know where to find the few out there but those who don't, check this out. I know I can't afford it maybe one of you can haha.
    Free Shipping - Chevrolet Performance 10051141 with qualifying orders of $109. Shop Engines, Bare Blocks at Summit Racing.
    1998 Chevy M VIN Mali LS with 99 Olds J VIN 3100 Swap
    Sealed power skirted hyperuetectic pistons, LS6 Valve springs, Manley keepers and retainers, Custom short ram, header back, Tuning by Performance Dyno, 3400 TB, MSD Coils and wires, A/C Delete, Gasket matched heads and intake manifolds, 180 hypertech stat, Cat delete, 2 1/2" header back.
    hmmm..... so is it a gen 2 or gen 3?
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Looks like a RWD block.
      • NFSINSANE
        • Aug 2009
        • 32
        It says it's for a 2.8 but it looks exactly like my 3100 cast iron. But if I had the money I'd just build a 2.8 if that was the case cus that block is a godsend for 60 V6 lovers!
          almost 4K for a gen1 block? fuck that, NEXT!
          • NFSINSANE
            • Aug 2009
            • 32
            actually I can see what you mean, theres a mounting spot on the front of the engine
            • NFSINSANE
              • Aug 2009
              • 32
              Heres another article on it if anyone wants to read more in it.
              • geldartb
                The Situation
                • May 2004
                • 1994
                Engine Block Weight (lbs) 59 lbs. for this one
                whats the regular block weigh in at.
                99 Grand Am GT
                1357 cam 227 233 .050 dur
                515 515 lift 112 lsa
                • NFSINSANE
                  • Aug 2009
                  • 32
                  In one these 2 urls I think it says the aluminum block is 47 lbs lighter than the cast block.
                  • neo71665
                    its this big
                    • Oct 2005
                    • 361
                    Wish I had the cash, I've heard rumors they can be bored out to 3.4L
                    87 3.4 4x4 blazer
                    • TheFly
                      86 Bird 2.8MPFI T5 3:42s
                      • Mar 2009
                      • 59
                      Hey that sure is a fancy hunk of metal.
                      There was pics on TGO of one used for racing in quarter midgets, had a crazy Warbol fuel injection on it, all the external oil pump goodies, somewhere in the 400hp range. Last one and last one I seen was a display engine at a speed shop being sold or something. Was like 90% ready. Got pic some where but lost em, though I never delete anything.
                      Though I got something that would go nice on it.
                      86 Pontiac Firebird
                      [68 Firebird hoodscoops, custom notchback,
                      custom rear mounted tach, inverted wing.]
                      http://thirdgenchat.org/viewtopic.php?f=4&t=58
                      I love my new notch-back. See link for better newer pics.
                        ever hear the phrase "too much airfilter"
                        • TheFly
                          • Mar 2009
                          • 59
                          Stole off my V8 car, as with winter I want to keep some heat in there.
                          Goes back on in summer.
                          But even then not really, a good 2/3s of it is blocked off on the inside up front. Allot of guy don't let ya see it but its done as open like that just the wind from the fan coming across it can screw with your carb. Why ya see real fancy one with hood pans to go one further. To isolate the carb from any and all under hood air, only incoming direct air changes settings.
                          86 Pontiac Firebird
                          • TiredGXP
                            • Jun 2008
                            • 107
                            Can't be a Gen 1 block if it has three oil galleries, Gen 1 and the Gen 2 block I have both had only two oil galleries. The Summit description stated it also had provision for timing sensors, so sounds like you could keep a DIS ignition system.
                            But for nearly $4k, it can stay in Summit's inventory.
                            • SofaKingWeToddDid
                              • Jul 2009
                              • 785
                              it also says it can be mounted for fwd or rwd applications. but yeah 4k for a bare bones block for a v6 seems a little extreme
