Intake manifold cleaning
  • 2.8-350TBI
    RWD FTW!!!
    • Sep 2009
    • 350
    Hey guys, happy new year first of all.
    I am in the process of cleaning my 3400 intake mani's and I cant seem to get all that nasty egr sludge off of the intakes. They spent about 4-5 hrs in a solvent bath earlier today and im sandblasting them tomorrow.
    Suggestions on how to thoroughly clean the insides?
    Originally posted by Mars
    Haha ^ Wrong Wheel Drive.
    No 60ºV6 at the moment
  • Killert
    Atleast it looks cool.
    • Dec 2008
    • 87
    Oven cleaner worked wonders on my intake!
    1988 Firebird
    3.4 60*V6
    9 Bolt Rear, 3.27:1, Disk brakes
    Edelbrock 3790 Cam & Lifters
    COMP Cams Magnum Steel Roller Tip Rocker Arms 1414-12
    COMP Cams High Energy Pushrods 7816-12
    COMP Cams Valve Springs 980-12
    PaceSetter Headers 70-1206
    • 2.8-350TBI
      RWD FTW!!!
      • Sep 2009
      • 350
      Guess I might wanna go try that out.
      Any others?
        Formula 88. Lowes sells it for ~$5/gallon. I bought a storage tote big enough to put a set of heads or an intake in to soak stuff in it. Formula 88 rocks, hands down. I'm glad Forced found it- that stuff removes carbon from runners ect. like you wouldn't believe. Just let the intake soak in it for a day or 2 and it should be good to go.
        • 2.8-350TBI
          RWD FTW!!!
          • Sep 2009
          • 350
          Never heard of the stuff before.
          Ya think 1 gal is enuff for the pistons and intakes?
          That sounds like the ticket...
            Live life 3.7mi at a time
            • 4555
            Only downside is it's expensive. You will want enough to completely submerge your parts. I would recommend that for someone who does a lot of parts washing.
            Used coolant woks too, that's usually free after a coolant flush
              I've never heard of using coolant. Too bad I absolutely hate coolant like no other automotive liquid on earth.
              • 2.8-350TBI
                RWD FTW!!!
                • Sep 2009
                • 350
                Im sooo with ^
                  • 4555
                  It has the same reactive chemical that Formula88 does haha. That's why your hands feel oily after being in the 88.
                  • 2.8-350TBI
                    RWD FTW!!!
                    • Sep 2009
                    • 350
                    What is this chemical?
                      • 4555
                      glycol monbutyl ether is Formula 88 and coolant is ethylene glycol
                      • SofaKingWeToddDid
                        • Jul 2009
                        • 785
                        Gunk brand Gel Degreaser in a spray can if the parts are above freezing temp, you spray on, and since its a gel, it stays where you spray it. let it soak for 10 - 15 mins and a pressure washer takes almost everything away, what was left inside my intake was stripped away with wheel cleaning acid. lol was available and i pressure washed the crap out of it. (mind you i think this intake is sitting on a shelf somewhere in my shed or garage)
                          Mine don't feel oily after being in 88. 100 cheap blue nitrile gloves from Harbor Freight for $5 FTW! They rocked for packing and installing new wheel bearings on the passenger side of my truck before going some place important. No wheel bearing grease stained hands
                            • 4555
                            I don't pack bearing by hand anymore, I can't stand having grease on them haha - I use a bearing packer - best $8 I ever spent (um $8 about 10yrs ago lol)...
                            Takes about 5 seconds to pack a bearing. Put it in the taper, put in the plunger and push till it oozes out. Just have to re-fill the container once in a while.
                              I've got the 2 cone style with a zerk on top. I used it 1 time and won't use it again, it wastes too much grease in my grease gun for my taste. Besides, for a true car guy packing bearings has a soothing effect
