dry nitrous on 3100
  • extremeskiier728
    • Mar 2004
    • 42
    dry nitrous on 3100
    ok for my first question is a dry nitrous kit essentially just a bottle with a solenoid valve and a specific nitrous nozzle located in the intake. if so i could technically just aquire these parts and make my own dry kit. if not what else do i need?
    second i were to run a dry nitrous kit ( not a "smart" kit, no change to fuel pressure or such) how high of a shot could i run. my ride is a 95 GA with 3100 and 4t60e tranny. for instance could i safely run just a 75 shot dry kit with out change fuel flow and not changing my timing a whole lot.
    thanks
  • RebelGT
    • 642
    no, 75 shot dry is alot more than i'd be willing to risk, dry kits are bad, they can more easily cause a lean out condition and cause your engine to become very unhappy.
    26+6=1
    • RednBlack
      Wood Hippie
      • Mar 2004
      • 2795
      Originally posted by RebelGT
      no, 75 shot dry is alot more than i'd be willing to risk, no dry kits are bad, than can more easily cause a lean out condition and cause your engine to become very unhappy.
      Use a wet shot system. I think I saw an easy one to replicate on a website. Goes in the closed end of a cone filter. I'm from the old world of tough V-8s carbed and gassed. Not used to TB and injection just yet. But a 50 shot sounds about right. Maybe ZEX.com? Don't really remember. And an unhappy engine can be buried with my 4t60-e tranny. Lil' weakling POS! Give me a 2spd Dogomatic! Or an FMX! F.....g newfangled, cheap-assed, computer controlled Wheel-Chock!
      • extremeskiier728
        • Mar 2004
        • 42
        ok still wanna know what a dry system consists of anyone know
        • Bryan1970
          • 23
          what you described is basicall all ther is to a dry N20 kit. it is basically 1/2 of a wet kit. and it would be a lot better just to buy a dry kit instead of piecing one together unless you know of someone that has extra N20 stuff around because most kits come with an assortment of jets to tune the system. plus just any nozzele probablly wouldnt work the best beacuse the nozzles made for N2O systems are designed to spray the N2O to mix properly.
          And a 50 shot would be the max that i would run through any engine with a dry kit. the dry kits just are somewhat of a gamble. if you go with too much N2O just once you can easily fry the engine. When you are tuning it look for metalic specs on the spark plugs. if there are some that means that the pistons are getting to hot and begining to melt.
          • extremeskiier728
            • Mar 2004
            • 42
            ok that helps if i would do that i would use it more than like once month on ocassion maybe twice. my engine is low mileage and runs strong very little wear. i just replace all the gaskets( head, lw manifold, plenum, exhuast, throttlebody) but i have not decided what im going to do yet.
            • StudlyCamaro
              • Nov 2003
              • 692
              once or twice a month LMFAO , you know its reffered to as "crack" right... yeah im only gonna try it and maybe use it on the weekends... pretty soon you are living in your car going to the speed shop to get "your fix" ..
              just a bit of advice.... i know a lot (im talking well over 20) crack heads (no not junkies, just speed freaks) and a handfull of them all had your mindset going into it and they will drain a bottle in a weekend night easy now...
              personally if i were you i would run a dryshot if you have an AFPR, and acess to a wideban dyno so you can "tune" it (not exactly a tune , but adding more fuel is a good idea, when spraying, than less fuel)
              if you arent going to have an AFPR or acess to a wideban i would deffinetly get a wet kit to lessen the chance of a lean situation
              however with a wet kit you need to be careful to have your timing perfect (AND NOT ADVANCED) or ur gonna have one hell of a firework show under your hood
              personally i would recomend a dry kit with a rough tune.. IMO its safer than having all the extra fuel in the intake manifold that is just waiting to backfire
              3.4L camaro some goodies
              • donk_316
                • Mar 2004
                • 427
                The answer he was looking for was
                "oh your engine is tight and super strong? well that changes everything! yes your cobbled together innacurate home made nitrous system will work flawlessly and give you many years of reliable service"
                1984 Indy Fiero 3.4L
                13.7 sec @ 98 mph
                *ALL THROTTLE AND NO BOTTLE*
                • dohcfiend
                  King Chalupa
                  • Jan 2004
                  • 2351
                  i wouldn't recommend it. i have a 50 shot wet kit and it ran lean twice with stock timing until i went 2 steps colder on the plugs(the downside is they foul). u want a 75 shot on a dry kit????? at least get an ignition controller and put a little nitrous retard in it(i recommend 5-7 degrees retard) if not u may damage your engine. of course it may be different with your motor since i have a dohc and u a pushrod but i doubt it. u will need to do a little research be4 u slap on that dry kit.
                  what a dry kit entails is this: bottle, a long line to your solenoid(double 4an), a short line from the solenoid(either double 3an or 4an/3an)to the nozzle,a n20 nozzle. that is for your n20 hardware, here are your wiring options: as far as i know u can have an arming switch/WOT activation switch setup(safest). or u can have an arming switch/manual n20 activation switch. i guess if u wanted to be REALLY cheap, i suppose u could bypass the arming switch and go with a manual activation switch.
                  • RednBlack
                    Wood Hippie
                    • Mar 2004
                    • 2795
                    Get a kit. Awesome post donk!
                    • StudlyCamaro
                      • Nov 2003
                      • 692
                      i dont see a problem with "making" one's own kit, when the time comes (if it does) i will be assembling my own kit(although i will be making a direct port setup most likely if i do spray my car), i can buy the line from an industrial supply store that will be more than sufficient, purchase a solenoid(s) cheaply used and rebuilt, nozzles dont really go bad on non forced induction cars, and switches are cheap. as for the saftey stuff, i'll probably buy a FPSS and a WOT switch
                      and CO2 bottles can be converted into N2O bottles, and they can hold more pressure than N2O bottles (not that i would need more pressure, but they are just as safe)(we dont want the NAWZZZ to blow up in the car )
                      • RednBlack
                        Wood Hippie
                        • Mar 2004
                        • 2795
                        Lemme know how it turns out.
                        • extremeskiier728
                          • Mar 2004
                          • 42
                          ok first off if you notice its says could i run 75 shot not i will run a 75 shot. second i never once said i was going through with this, i started this post so i can increase what i know so that if i would someday go with spray i can make an informed decision. and you guys need seem to have already passed judgement on people who consider nitrous as an option. (aka... their stupid shit and they will blow themselves up) so maybe you can calmly answer and not judge first.
                          • evilmiata
                            • Nov 2003
                            • 156
                            A dry system typically increases the fuel pressure to the rail while engaged. A wet system jets fuel and nitrous together into the intake. If you use a dry system without the extra fuel, you will experience a lean condition, knock, and likely burn through a piston. Its not a question of safety or not, but rather when you will break your motor. If you use a 75 shot without extra fuel, I bet that the first time will be your last. Of course, I could be wrong; maybe you could use it twice!
                            Remember: Nitrous doesn't make power. Fuel does.
                            • dohcfiend
                              King Chalupa
                              • Jan 2004
                              • 2351
                              don't take this the wrong way. but one of the best ways to increase your n20 knowlege to help you make an informed descision would be to buy a nitrous book. u can get them from summit, jegs or a local books a million might have one.
                              from my personal experience it is better to "get it wet" instead of dry. ok seriously, u will need to make more mods(hence spend more cash) to make a dry system work than a wet system something tells me u will need to compliment that xtra fuel pressure with bigger injectors. and most likely your car will be using that xtra fuel(running rich) all the time.
                              of course i don't have alot of room to talk cause mine runs rich and fouls plugs. but that is stock timing. after i get the $$$ for an ignition controller with n20 retard i can use regular plugs and even advance timing when not on n20 to optimize performance.
                              trust me wet systems are so easy on a fuel injected car it should be outlawed. a wet nozzle only cost 10 bucks more than a dry nozzle. and maybe studly camaro might be on to something with rebuilt solenoids if price is your concern. plus i had a post on how to get a brand new wet system for around 375 or 400 i think.
                              hope that helps
                              p.s. my system is a home built system. i got a carb system for a car body bought 2 18 in lines, and a nozzle. i sold the carb plate, and upgraded with a remote solenoid from ebay.
