? regarding Exhaust size
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    Looking to build Log Style headers for my 3500 Turbo App.
    Will this be ok in size?
    1.5" T's and 90* and piping to the Turbo?
    Actual inside Diameter would be 1.65"
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
  • Weatheralls Auto
    • Dec 2009
    • 536
    Or I guess I could use the 1.5" for the headers and then maybe 2.5" for the crossover and make my own T and go 2.5" to the T04 Turbo inlet?
    As of April 2
    Injectors: #36 GTPs
    TB: 65mm TCE
      2.5" inch crossover sounds WAY too big...
      • RedZMonte
        • Feb 2004
        • 1378
        I know most of the guys run 1 5/8 piping for headers on these cars so it sounds to me like anything from 1.5"-1.65" will be fine.
        I would run either a 2" mandrel or a 2.25" at most for the crossover and do a 2.5" downpipe (3" if it fits but 2.5" is sufficent). Keep in mind if the Manfold outlets are 2" or smaller then i would run 2" X-over to keep exhaust gas velocity as high as possible. plus it makes it much easier to fit your downpipe in there.
        here is a nice pic of the Crossover collecting to the turbo (found on clubgp)
        S
        Shane "RedZMonte"
        1992 Lumina Z34-VIRGIN (RIP)
        1992 L67 Lumina Z34 (SOLD)
        1990 Turbo Grand Prix (SOLD)
          that's actually nice. most of the attempts i've seen look like someone went half-assed, as soon as they got to the turbo flange: just a horrible 90* outlet.
          • Weatheralls Auto
            • Dec 2009
            • 536
            Ya, that looks nice, however, with the space, or lack of, that I am dealing with, I was planning on (looking at that Pic) rotate the Turbo 90* Counter clockwise, T off crossover to a 90* up to inlet flange, 90* out to down pipe, from ram air hood 90* inlet then down to intercooler and back.
            Lol, can ya picture that?
            Main reason is if I install like in the Picture, I would need a 180* turn from inlet of hood to inlet of compressor
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
              i need a 3d model or cross sectional drawings to figure out what you're saying
              the more i think about it, the more that setup looks like the optimal way of making a single underhood turbo system...
              nice and smooth bends, not too many of them...
              the only issues i see with all of that is routing the piping to the intercooler, though the compressor is clocked the way i would want it to do so... also am not sure if i see a wastegate or not...
              too bad it's hooked up to the fail motor...
              • Weatheralls Auto
                • Dec 2009
                • 536
                good point, if I were to do it that way, where would I put the external WG?
                As of April 2
                Injectors: #36 GTPs
                TB: 65mm TCE
                • RedZMonte
                  • Feb 2004
                  • 1378
                  the External WG is on the rear pipe of the X-over and dumps externally.
                  Idealy you would want to have the WG connected to both front and rear banks of the Xover but with the space its easier said then done in most cases. Mine is off the front bank mostly.
                  Shane "RedZMonte"
