Ignition wires
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    Ignition wires
    I have a 3500 with the 3400 ign set up.
    I am wanting to hide the wires as much as possible.
    Would the 3.1 code T wires be long enough?
    Was thinking if I could route the front wires to the back under PS pump? Long enough.
    And would the shorter wires be long enough for the rear bank?
    Anyone try this? or something similar?
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Buy a V8 set that you cut to fit and you will get plenty of length to put them anywhere.
    • Weatheralls Auto
      • Dec 2009
      • 536
      Couldn't find a V8 with ones long enough.
      I just measured;
      Need 3 @ 50" and 3 @ 16"
      Can get some Hi Performance bulk, but need to buy minimum 50' @ 2.27 per '
      so $114,
      Not sure if I should go that route or not, I have lots of ends and boots.
      As of April 2
      Injectors: #36 GTPs
      TB: 65mm TCE
        Nicely run wires look hot though... LOL
        I was going to recommend a V8 set too, but apparently they don't have wires long enough.
        Bulk isn't that restrictive either... you need just over 16 feet of wire, 16.5 to be exact... so get a 20ft roll.
        Get fast, Free Standard Shipping on orders over Summit Racing Equipment from $109 -- no shipping, handling, or rural fees! Exclusions apply.
        25ft of 8.5mm black is only $48
          i made my Taylor Spiro-Pros with leftover wire (and the stock terminals and boots )from when i did the El Camino...
          • Weatheralls Auto
            • Dec 2009
            • 536
            Ya, I found this online, just wonder how long it would take to get to Canada, and with Customs and exchange, may be cheaper to get the stuff here at 144 bux lol
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
