I have searched for this, but have yet to find it. I am building a 3.1 from my 87 S10 2.8. I have the crank from a 94 camaro 3.4, going .030 over and adding a crane 2030 cam. I see that you need to upgrade to 4.3 injectors for the 3.4, but how about for this 3.1? If I have to do this should I upgrade the entire TBI or just swap the injectors? Appreciate any help.
2.8 upgrade to 3.1
First off if you have not bought the cam yet then DON'T. It is not a great cam. A Crane or Comp 260 cam is MUCH MUCH better. You should be fine with your 2.8L injectors. If you find a Rodeo in the junkyard with a 3.1L then Grab the ECM because it will run your 3.1L perfectly. By the way you can go .040 over and make yourself a 3.2L1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
ditch that cam, it's a joke.
