Is Ow-20 synthetic too thin for 3500Turbo?
  • FallenZ24
    • Nov 2005
    • 178
    I have a supply of Toyota brand Ow-20 synthetic that I've acquired through work. I'm just wondering if this oil is going to cause any issues with the 3500 or my turbo. The turbo is rebuilt. The engine doesn't leak a drop and I've been running 5w-30 mobile1. I can also get this oil at a very good price since I work at a Toyota dealership.
    Maybe I can get more mpg's running this also. It really makes a difference in the 2010 prius. Haha! My Fiero may have unexpected acceleration though... lol!
    -Joseph
    i wouldn't run 20 weight oil... true, it takes less power to move, therefor a fuel economy increase, but you could be seriously shortening the life of your engine...
    however, you could mix it with some, say 5W-30 and then i would call it acceptable.
    • 86FieroSEv6
      • Feb 2010
      • 527
      Your engine has to be setup for 20w use. I don't have a problem with the cold vis. being 0, but 20 for hot vis isn't going to cut it for your V6. Believe it or not, I would recommend using euro spec 0-40 for your setup.
        damn, i didn't even know they made 0-40... not a cheaper sythetic obviously...
        • 86FieroSEv6
          • Feb 2010
          • 527
          Good point, but oil at any price is cheaper than an engine. 0-40 is made by several different manufacturers, just look for "euro-spec" and don't be afraid to call the VW dealer down the street for price, then check on AMSOIL and I believe Castrol makes one too. The euro-spec oil is especially formulated to avoid sludge buildup which was a problem for VW for a while which is why I like it.
            Maybe Chrysler should have looked into that for their 3.5l V6 I think it was...
            • discostu
              • Jul 2005
              • 105
              Most heavy duty (aka Semi-truck, Kenworth, Peterbilt etc) places will carry 0W40 diesel oil. Standard oil for heavy duty engines is 15W40 and the full synthetic is 0W40. I'm guessing it would probably be cheaper then buying "euro spec" oil too. I know that the new diesel oils are CJ-4 spec "low ash" aka low emissions oil, but I'm not sure about their sludge characteristics.
                I wonder if the new diesel oils have zinc still...
                • 86FieroSEv6
                  • Feb 2010
                  • 527
                  Nyet . . . . if there is any zinc at all it is in such low concentrations as to be useless. I protect my rods by putting a bottle of synthetic Lucas oil treatment in with the oil. Good stuff.
                    from what i understand, they CAN have more than the SL(?) gasoline oils we have now...
                    • discostu
                      • Jul 2005
                      • 105
                      It's on SM now.
                      Search on www.bobistheoilguy.com they have all the best information about oil properties such as particle counts.
                      • geoffinbc
                        Iron Head Enthusiast
                        • 5831
                        There is no reason you cannot run 20 weight oil. The engine type does not designate the oil you must run. The way you build the engine will determine what engine oil you will need to run to maintain protection. If you build a tight motor with a good oil system then go ahead and run 20 weight oil. Hell if a stock 3X00 maintains good oil pressure at hot idle then it would run just fine on a quality 20 weight oil.
                        For a good example plenty of guys in the engine masters challenge were running 0W20 oil on what most would consider "old iron" but they ran tight bearing clearances thin ring packs and employed good oil control and pumps.
                        • 86FieroSEv6
                          • Feb 2010
                          • 527
                          ^^^ this ^^^
                          After years of running Valvoline racing 50, I finally convinced by buddy to move to a multi vis synthetic and he came back grinning from ear to ear about the power increase.
