Edelbrock intake / Holley carb on a 2.8
  • Heavy D
    • Dec 2008
    • 2
    Can someone help me out here? I have a 1984 Chevy S-10 with a 2.8L and an automatic transmission. I recently acquired an Edelbrock Torker intake (part number 3785 base and 3789 top) and a Holley 8007 390 cfm carb on the way. I want to have everything laid out to do the swap without mulitple runs to O'Reilly's and Autozone, so my question is this; which brackets am I going to need to do the install? Will I need the 700R-4 Kickdown Throttle Bracket (Holley part number 20-121) or the GM AOD Kickdown Cable Bracket (Holley part number 20-95) or will I need both? If anyone else out there has done this, any help/advice/guidance would be greatly appreciated.
    I have this question posted on the S-10 forum, and keep getting answers like "You'll need RTV and oil"...well duh. I just need to know what brackets to use. Thanks for any help you can provide. Also, it's been a while since I have been on here and the layout is different, so if this is in the wrong forum I apologize.
  • Heavy D
    • Dec 2008
    • 2
    Nothing? Come on guys!
      • 9191
      Welcome! Unfortunately, FWD guys are more prominent around here than the RWD guys. But there are some, so give it a day or 2 and hopefully some one will be able to answer your questions.
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        Easy man you don't always get an answer the same day. Most of us do have day jobs.
        You have a 700R4 trans. Get the kit. If the stock bracket wont work then you can use the Holley one. If it does work take the Holley one back.
